POV-Ray : Newsgroups : moray.win : animation rendering stops after first frame Server Time
17 Nov 2025 04:50:13 EST (-0500)
  animation rendering stops after first frame (Message 1 to 4 of 4)
Subject: animation rendering stops after first frame
Date: 25 Sep 2004 16:10:01
Message: <web.4155cffc1d66f858f1bb1c350@news.povray.org>
Hello,
I have strange problems with the animation plugin.
When I render the animation with POV, then only the first frame is rendered
and then POV is going idle. In the animation option menu I can see the job
still being active, but in reality it is not rendering (no CPU usage).
When I choose other renderers in Moray for the animation, like wireframe or
raytracing, then all frames are generated and an .avi file is generated.
The same settings with the renderer "POV" just render the first frame.
Is there something, that I am missing (e.g. some settings inside POV that
prevent further rendering), or is it a bug?
I use Moray 3.5 build 9330 and POV 3.6 under WinXP SP1.
Subject: Re: animation rendering stops after first frame
Date: 25 Sep 2004 19:08:35
Message: <4155fa73$1@news.povray.org>
Pov 3.6 and Moray 3.5 don't get along so well. Try using Pov 3.5 instead.
Date: 28 Sep 2004 15:43:13
Message: <4159bed1@news.povray.org>
In order to build animations using POV-Ray as the renderer, a POV-Ray
GUI extension is provided.  This extension (in the form of a DLL), must
be located in the same directory as AnimPlugin.dll, or somewhere on your
PATH.
If the Animation plugin communications is being recognized, you should
the message,
GUI Extension 'Moray Animation Plugin' loaded from 'AnimGuiExt.dll'
Report any problems to Alexander Enzmann <are### [at] hotbotcom>"
at the top of the POV-Ray messages window.  This shows it has been
loaded properly.
If, on the other hand, the connection isn't made, you may see this message:
Could not load GUI Extension 'AnimGuiExt.dll'
This indicates that although the animation plugin has told POV-Ray how
to make the connection, either the dll isn't in the proper place (the
Moray plugin directory), has been renamed somehow, or has been
corrupted.  If POV-Ray tried and failed to load AnimGuiExt.dll, then
look in the file "pvengine.ini" (which will be in the "ini" subdirectory
of the main POV-Ray directory).  There should be entries that look like
this:
[GUIExtensions]
UseExtensions=1
ExtDll15=C:\MORAY\MorayCtrl.DLL
ExtDll29=C:\MORAY\Plugins\AnimGuiExt.dll
Make sure the line that starts with ExtDll29 has the correct directory
and name for the animation plugin.  The path should be the main Moray
directory followed by "Plugins", followed by "AnimGuiExt.dll".  If this
is incorrect, fix it and then restart POV-Ray.
[Note also that POV-Ray won't be invoked for animations unless you also
select it as the renderer in the rendering options dialog.]
jens wrote:
> Hello,
Date: 30 Sep 2004 15:20:00
Message: <web.415c5b81727821189c9e6aa60@news.povray.org>
> this:
> [GUIExtensions]
> UseExtensions=1
> ExtDll15=C:MORAYMorayCtrl.DLL
> ExtDll29=C:MORAYPluginsAnimGuiExt.dll
Many thanks! That was exactly the information that I was missing. I didn't
know that the animation Plugin of Moray uses a separate communication DLL
for POV. And somehow it didn't get installed correctly. With your tip it's
working as expected.
Thanks
Jens
