POV-Ray : Newsgroups : moray.win : Announce: 3DWin 4.1, a 3D file format converter Server Time
10 Jun 2026 16:02:12 EDT (-0400)
  Announce: 3DWin 4.1, a 3D file format converter (Message 1 to 10 of 24)
Subject: Announce: 3DWin 4.1, a 3D file format converter
Date: 15 Jul 2000 03:05:11
Message: <9130nsgao5vba7ft76lltf2q13330gbl3a@4ax.com>
this program is a small utility to view and convert 3D
files to a number of other 3D formats. Beside well known
features from V3.5 now full material conversion is supported.
3DWin is available at
	http://www.stmuc.com/thbaier/tools.html
What's new:
  * 3dto3d engine supports now solids like sphere, cylinder etc
  * Protein Data Bank (*.pdb) import
  * bug in OpenGL export fixed
  * Batch import (registered version only)
The Basics:
  * running unter Win95/98/NT4/W2K
  * easy installation
  * plugin architecture
  * updates via support web page.
  * clear and comfortable userinterface
  * full help support
  * robust and fast conversion routines
  * reliable handling of larges scenes
  * detailed statistics about conversion process
  * supports polygon meshes including normals and uv vectors
  * supports light and camera conversion
  * supports material and image map conversion (registered version
only)
   Import:
   	Generic ASCII format (*.raw)
   	3dStudio (*.3ds, *.prj)
   	Lightwave (*.lwo, *.lws)
	Autodesk (*.dxf)
	WaveFront (*.obj)
   Export:
   	3dStudio (*.3ds, *.asc)
   	Lightwave (*.lws, *.lwo)
   	Autodesk (*.dxf)
   	VRML 1.0/2.0 (*.wrl)
   	POV-Ray and Moray (*.inc, *.udo)
	WaveFront (*.obj)
	OpenGL (*.C)
	Renderman/BMRT	(*.rib)
	Lightflow	(*.py)
Subject: Re: Announce: 3DWin 4.1, a 3D file format converter
Date: 16 Jul 2000 15:36:42
Message: <39720eca@news.povray.org>
Hmm .. recently noticed that I can't load a lightwave-R6-Object
Is there a incompatibility between earlier versions ???
PS: I'm still using v3.5 of 3DWin ... is this the reason ???
(Should I update ???)
 ,',    Jan Walzer      \V/  http://wa.lzer.net     ,',
',','   student of      >|<  mailto:jan### [at] lzernet ',','
  '   ComputerScience   /A\  +49-177-7403863         '
Date: 17 Jul 2000 00:32:06
Message: <2q25ns8hmnrrinhk209ivvv1qeh72cbh56@4ax.com>
On Sun, 16 Jul 2000 21:40:08 +0200, "Jan Walzer"
<wal### [at] informatikuni-hallede> wrote:
3.5 and V4 do not have support for LW6 but it is on my todolist :-))
-tb
Date: 17 Jul 2000 15:26:45
Message: <39735df5@news.povray.org>
Is there another way to do this ??? How can I get my LW6-Mesh
into Moray (or POV)?
Date: 17 Jul 2000 15:40:15
Message: <39735FC2.624E0059@pacbell.net>
There probably is no way to do so unless you have LW6 and it
can export to a different 3D file format that 3DWin supports
such as .dxf, .3ds, .obj....
Date: 17 Jul 2000 16:31:46
Message: <39736d32@news.povray.org>
hmm... I thought so ... :-(
Date: 20 Jul 2000 15:37:40
Message: <39775504@news.povray.org>
I'm having some difficulty exporting a Moray .udo/.inc.  The only export
format I can find is .pov.   Am I doing something wrong?
"Thomas Baier" <NOS### [at] stmcucom> wrote in message
news:9130nsgao5vba7ft76lltf2q13330gbl3a@4ax.com...
What's new:
The Basics:
  * easy installation
  * full help support
only)
   Import:
Autodesk (*.dxf)
WaveFront (*.obj)
   Export:
   Autodesk (*.dxf)
WaveFront (*.obj)
OpenGL (*.C)
Lightflow (*.py)
Date: 20 Jul 2000 15:58:10
Message: <397759d2@news.povray.org>
Never mind, I just found the checkbox.  Thanks anyway.
"Dennis McDaniel" <hyp### [at] yahoocom> wrote in message
news:39775504@news.povray.org...
What's new:
The Basics:
  * easy installation
  * full help support
only)
   Import:
Autodesk (*.dxf)
WaveFront (*.obj)
   Export:
   Autodesk (*.dxf)
WaveFront (*.obj)
OpenGL (*.C)
Lightflow (*.py)
Date: 20 Jul 2000 18:17:54
Message: <39777a92@news.povray.org>
Okay, I checked all of the options and still can't find an answer to my
problem.  I can create the .udo/.inc and import the .udo into Moray, and
assign it a material--but it just won't render.  HELP!
TIA
What's new:
The Basics:
  * easy installation
  * full help support
only)
   Import:
Autodesk (*.dxf)
WaveFront (*.obj)
   Export:
   Autodesk (*.dxf)
WaveFront (*.obj)
OpenGL (*.C)
Lightflow (*.py)
Date: 21 Jul 2000 00:38:07
Message: <ukkfnskh7m502rf0tck1giasgrbd1od4i2@4ax.com>
On Thu, 20 Jul 2000 15:16:40 -0700, "Dennis McDaniel"
<hyp### [at] yahoocom> wrote:
be sure to select the right POV-Ray version. It wold be good, if you
download Mega POV with UV support.
-tb
>TIA
>Hi,
>What's new:
>The Basics:
>  * easy installation
>  * full help support
>only)
>   Import:
>Autodesk (*.dxf)
>WaveFront (*.obj)
>   Export:
>   Autodesk (*.dxf)
>WaveFront (*.obj)
>OpenGL (*.C)
>Lightflow (*.py)
