POV-Ray : Newsgroups : moray.win : YAAFR Server Time
17 Nov 2025 00:08:57 EST (-0500)
  YAAFR (Message 1 to 4 of 4)
Subject: YAAFR
Date: 19 Jan 2006 14:50:12
Message: <43cfed74$1@news.povray.org>
Would be nice to be able to use negative values for light parameters.
Tim Cook
Version: 3.12
Subject: Re: YAAFR
Date: 19 Jan 2006 16:55:29
Message: <9m20t1h8k3dri8qchntpeiqqchsc8tpvvf@4ax.com>
On Thu, 19 Jan 2006 14:50:08 -0500, Tim Cook <z99### [at] bellsouthnet>
You'll be lucky :-)
I would like some way to edit the search paths better.
Subject: Re: YAAFR
Date: 23 Jan 2006 23:41:15
Message: <5ubbt1lob06e0eq318g3967r5opt6jh5oa@4ax.com>
Hi Stephen, you recently wrote in moray.win:
Can you explain why? Or how? Or why the current way is
bad/cumbersome/not good? :-)
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
Subject: Re: YAAFR
Date: 24 Jan 2006 03:53:22
Message: <9lqbt1hanag5ip7spki47me43js9721974@4ax.com>
On Mon, 23 Jan 2006 20:41:18 -0800, Lutz Kretzschmar <lut### [at] stmuccom>
I want to change all of my data files (mdl, udo, maps etc.) to another
drive. In Moray I have to individually step through the new directory
structure for each of them. Also when I want to put an entry in
povray.ini I need to type in the library path. If you created an edit
button that brought up an editable path field that I could over type
manually. This would allow cut and paste to and from the paths. It
should also have a browse function as well.
I did my mass change in the registry but I don't think that is good
working practice.
