POV-Ray : Newsgroups : moray.win : Feature request simple this time? :/ Server Time
13 Jun 2024 07:54:14 EDT (-0400)
  Feature request simple this time? :/ (Message 1 to 4 of 4)
Subject: Feature request simple this time? :/
Date: 27 Apr 2004 09:26:00
Message: <408e5f68@news.povray.org>
Hi Lutz :)
I'm an intensive user of Luis' InsertCode plugin
I often need to use an object created in moray in a macro or a piece of
code.
For example an object dropped on a heightfield by the trace() function
To get these objects #declared in Pov export file, I have to duplicate them
as referenced objects.
Should it be possible to have a check box close to the "export" one named
"declare" so that the object could be in the declarations section of export?
Does it make sense?
Thanx
Marc
Subject: Re: Feature request simple this time? :/
Date: 27 Apr 2004 09:38:35
Message: <408e625b@news.povray.org>
news:408e5f68@news.povray.org...
> Hi Lutz :)
> code.
them
export?
> Does it make sense?
> Thanx
> Marc
Yes, it's a good feature, i think.
Not only for using InsertCode, but also to retrieve correctly one object in
a plugin, for example.
And It could be a new Attribut Object, like others. To solve compatibiliy,
this checkbox must to be checked if the object is referenced, and per
default not checked if not.
Luis
http://www.lightning-generator.org
Date: 28 Apr 2004 00:56:36
Message: <oaeu80df2haeeusoc6dfrvfb546h31v3m2@4ax.com>
Hi Marc Jacquier, you recently wrote in moray.win:
I need to think of all the cases that this touches.... theoretically,
it should not be a problem, since the reference object already does
part of this....
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
Date: 28 Apr 2004 05:37:38
Message: <408f7b62$1@news.povray.org>
I support this idea
> Hi Lutz :)
> code.
them
export?
> Does it make sense?
> Thanx
> Marc
