Hello,
I downloaded the Moray 3.5 and installed it fine.
Now I open it and create a "Trans" from the Spline Objects. click on Edit at
the tab register but why i cant see the Spline Editor?
I'm a beginner with the program.
> Hello,
at
You are looking at the spline Editor. If you want a more typical view of
your spine, try the following.
From the Spline Edit tab, select 'Local' from Coordinate System, un-select
'Wire' from Display and Export, place mouse over the 'top view' window and
press 'w' (shortcut for full screen).
Hopes this helps.
Thx.
I found it and creates a first sample. ;-)
"StephenS" <ssh### [at] ottawa net> schrieb im Newsbeitrag
news:401e4c48@news.povray.org...
> > Hello,
Edit
> at
> Hopes this helps.
> Stephen
