I tried an even simpler animation and the results are less dramatic, but it
still crashes every time. Sometimes it just shuts Moray off instantly,
sometimes it tells me it's shutting off first, and sometimes I get this
message first: Debug error! Program C:\....MorayWin.exe Damage: after
normal block (#6046) at 0x14061600. I tried re-installing Moray, and that
made no difference. :^(> Help!
Steve Shelby
> Steve Shelby
You didn't mention what version of the animation plugin you are trying to
use. The one that came with Moray 3.5 or the updated version on Moray's
plugin page?
This won't help me but maybe someone else, I have very little experience
with animations.
Check to make sure that you are, in fact, using POV as the renderer
in the Render:Options section...
"Tim Cook" <z99### [at] bellsouth net> wrote in message
news:3ff84667@news.povray.org...
AHAH! It was set on "Raytracing" which at a glance, looked like it should be
the correct setting, and it did work fine for rendering stills; it called up
Povray and rendered just like it should. I set it on "POV-Ray" and all is
well, now. :^)> THANK YOU.
Steve Shelby
