All,
I am trying to reconstruct an old .mdl file that contains a lot of UDOs that
point to certain include files. However, my PC setup (ie - install path,
file locations, etc) is now different from when I first constructed this
file. When I go to render a frame, the generated POV file includes several
lines similar to:
Error: Name of include file for 'lower_mold_in' not known!
... one for each UDO that the file contains, but is no longer linked to the
include.
Is there a way to modify the path(s) to the include files for each UDO? I
would rather not have to re-import each UDO and have to set everything back
up (there are a lot of animation keyframes, materials, etc. that would be a
lot to re-do...)
TIA,
-Kman
Subject: Re: Reconstructing old project... include file question
Date: 13 Jun 2003 12:03:41
Message: <3ee9f5dd@news.povray.org>
Well, you could let povray know about the
directory where the UDO's are. Ofcourse
this requires that the searchpath is not hardcoded
in your .pov and .inc files.
/Stefan
"Kman" <mzu### [at] yahoo com> wrote in message
news:3ee7439c$1@news.povray.org...
> All,
that
> lines similar to:
the
> include.
back
a
> lot to re-do...)
> TIA,
> -Kman
Date: 13 Jun 2003 15:31:42
Message: <3eea269e$1@news.povray.org>
Thanks for your response, Stefan! I thot for a while that everyone's moved
over to the .beta section, and I was fixin' to copy this message there...
Yes, this is exactly what I need to do, and I thought I accomplished this
within Moray - the path to where the new .udo and .inc files are has been
added - but Moray is not re-linking the UDOs already within the .mdl file
(imported and set up before the changeover) to the new .udo and .inc files
(re-generated and re-located since my PC changeover). This fact is apparent
because they are not displaying in the 3D views. I could go through and
re-import all the newly regenerated files, but that would mean that I'd have
to set up all the animation, materials, and such for each, and there's a
bunch of them.
You're saying that there's a setting in POV-Ray that I should be looking at?
How come Moray is not displaying them? Also, the generated POV file with the
"Error" lines I mentioned below was created by Moray at the time of render -
its saying it can't find the associated data files, so it must be a setting
within Moray. Any thots how to re-associate these udos?
TIA,
Kman
"Stefan Persson" <azy### [at] telia com> wrote in message
news:3ee9f5dd@news.povray.org...
> /Stefan
> > All,
> that
several
> > lines similar to:
> the
> > include.
I
> back
be
> a
> > lot to re-do...)
> > TIA,
> > -Kman
Hi Kman,
have you tried View|Dependencies? I'm not entirely sure if that will
fix it, though. Other than that I can only think of the UDO files
containing absolute paths. In that case you would have to edit the UDO
files and change the paths in them....
- Lutz
email : lut### [at] stmuc com
Web : http://www.stmuc.com/moray
