When I create reference objects in moray and then import the scene into
PovRay to do other things to it there that Moray can't do, PovRay does not
seem to recognize the referencing. Is there a way around this?
Steve Shelby
3e3bcf84@news.povray.org...
> Hi,
> Steve Shelby
It has never happened to me.
Could you send some code?.
Txemi Jendrix
http://www.txemijendrix.com
Txemi,
I found out that it works OK with ordinary transformations. What I can't get
to work is "bend", using Chris Colefax's bend.inc. It works fine on a single
object, but not when reference objects are added. I'm sending files to
moray.binaries under the same subject line.
Thank you,
Steve
Txemi Jendrix <tji### [at] euskalnet net> wrote in message
news:3e3c0b38@news.povray.org...
> > Hi,
not
> > Steve Shelby
> Txemi Jendrix
Hi Steve Shelby, you recently wrote in moray.win:
> What I can't get to work is "bend", using Chris Colefax's bend.inc.
It's likely more an issue of bend.inc than Moray. Maybe you can ask in
povray.general why it won't work, since I have no idea how bend.inc
does it's work.
- Lutz
email : lut### [at] stmuc com
Web : http://www.stmuc.com/moray
Lutz,
I emailed Chris Colefax a few days ago, and finally got an answer. He had
the solution; it's very simple, but not something I would have ever been
able to come up with on my own.
Steve
Lutz Kretzschmar <lut### [at] stmuc com> wrote in message
news:9lvq3vgn4hqrr5dipat359a6b94a61rufj@4ax.com...
> does it's work.
> - Lutz
> He had > the solution; it's very simple, but not something I would have ever been
Care to share it?
- Lutz
Lutz,
I was wondering if someone would bite on that ;~^)-
Here's the pertinant part of Chris's post:
"To use multiple bent objects you can declare the
results of the bend:
#declare [bend options here]
#declare BentObject = #include "bend"
object {BentObject translate x*10}
object {BentObject scale 2 rotate y*90 translate -z*5}"
The important thing being the second line. "BentObject" would be the name of
the object. The parent object and all of the reference objects all have the
same name.
Hope that helps.
Steve
news:trjt3vgm0uc9etcb49qqfp6194aq4m9n98@4ax.com...
ever been
> Care to share it?
> - Lutz
