Aargh! I don't know what happened! I try to start Moray (like I always do,
either directly or through POV-Ray), the start screen appears, loading the
plugins, says it starts Moray, and....then nothing! No Moray screen.
Started the computer up again... no change.
Something must have been gone corrupt somewhere... Please help! What should
I do? Apart from loading Moray again, of course...
Thomas de Groot
> Thomas de Groot
I had the same problem about a year ago, one of Moray's dll files had
been corrupted, in the end I had to reinstall Moray, it did give me an
excuse to move up to a newer version.
Alex
,-._|\ Alex McMurray
/ Oz \ ale### [at] melbpc org au Melbourne PC User Group.
\_,--.x/ Melton. Vic. 3337 Australia
v
Well, it still doesn't work!
I uninstalled Moray, and installed it again without problems, but apart from
the startup screen, Moray doesn't start at all!
Help Lutz! Any idea??
Thomas de Groot
"Alex McMurray" <ale### [at] melbpc org au> schreef in bericht
news:3CD9965A.4290970C@melbpc.org.au...
> Alex
> v
Hi Thomas de Groot, you recently wrote in moray.win:
No idea why that would happen.... The only thing I can suggest is that
you use Regedit to delete the
HKEY_CURRENT_USER/Software/SoftTronics/Moray For Windows key and try
again (you will lose all your settings like Search paths etc.)
Did you change anything in your system? Install anything?
- Lutz
email : lut### [at] stmuc com
Web : http://www.stmuc.com/moray
"Lutz Kretzschmar" <lut### [at] stmuc com> schreef in bericht
news:2sqmdu0s8vvcgmafo51fc42uhbs0u5j50v@4ax.com...
==> Thanks a lot indeed Lutz! This helped, and Moray seems to work again
fine (at least it loaded up normally after reinstallation).
==> Not that I am aware of. I installed a new version of Hamapatch, but I
don't think that was the problem...
What about this: I use several different versions of POV: v.3.1, MegaPov6,
MegaPov7, and PovMan (for the Cloth utility). Normally I have one POV
assigned to Moray, but lately I tried to start up Moray from another POV
version, would that be the origin of the trouble? It is the only thing I can
think of...
Thomas de Groot
> - Lutz
> ... but lately I tried to start up Moray from another POV
Hmmmm. Not sure. I don't really think so. The DLL that connects
POV-Ray and Moray hasn't changed, so all your versions load the same
DLL and the same Moray..... You don't run two different POV-Ray
versions at the same time, though, do you? That might be a bit
problematic.....
- Lutz
Hmm, another possibility was a missing plugin-connection-error behind
the startup-message box. I think i got those one or twice with the
lua-plugin. I tried to load a scene, but the lua-file was missing, and
the error-box was hiding somewhere, where i couldn't find it.
But this should be solved after a reinstall i think.
greets
Arne Kleinophorst
P.S. Something new for the 3.5-beta??
news:5tnnduc17l59lbovh5e5otl5jejo5ce5ah@4ax.com...
> problematic.....
==> No, I didn't. So the mistery remains...
However, what Arne says about the Lua plugin could make sense perhaps. Is
there a possibility that, once in a while, the connection to a plugin is
lost? But as far as I could see, all the plugins were loaded successfully,
and the last mention I could read was "starting Moray". Then the screen
disappeared, thus before the mention "starting OpenGL". Could it have been
an OpenGL problem??
Anyway, everything is fine again. I'll remember the register key however if
it happens again... Thanks!!!
Thomas de Groot
