POV-Ray : Newsgroups : moray.win : Making a curved pipe Server Time
10 Jun 2026 03:22:59 EDT (-0400)
  Making a curved pipe (Message 1 to 7 of 7)
Subject: Making a curved pipe
Date: 11 Jan 2002 20:43:05
Message: <3c3f94a9$1@news.povray.org>
Can anyone tell me the best technique to use in Moray to make a pipe that is
curved rougly in the shape of the letter C?
Mitch
Subject: Re: Making a curved pipe
Date: 12 Jan 2002 00:02:14
Message: <3c3fc356@news.povray.org>
I discovered that a torus with a plane cutting it in half is one way to do
this but I am wondering if there is another way that is more flexible and
lets you "bend" the pipe in more creative ways?
"Mitchell Waite" <mit### [at] dnaicom> wrote in message
news:3c3f94a9$1@news.povray.org...
is
> Mitch
Date: 12 Jan 2002 00:54:14
Message: <3C3FD0E4.CD33478@applesnake.net>
not sure on Moray, but there's an app out there that did this...
but you'd need to go through Ken's links to find it.  However,
there are a million ways to skin a cat...
http://home.pacbell.net/tylereng/
-peter
> is
> > Mitch
Current obsession: "Ballet pour ma fille."
http://www.applesnake.net
Date: 12 Jan 2002 07:42:35
Message: <3c402f3b@news.povray.org>
There's a Spline-Plugin (look at the moray-homepage), that will allow you
even more complex pipes ..
"Somehow what you suggest is like suggesting to add drills \ jan### [at] lzernet
to cars so you can drill for oil when you run out of fuel.  \
Sure you could do it, but it might not be the most practical >          Jan
solution." [Thorsten Froehlich in p.u.p]                    /        Walzer
Date: 12 Jan 2002 08:19:28
Message: <3c4037e0@news.povray.org>
failing that, give sPatch a whirl - you can export your creations directly
to moray
PGP Public Key
Date: 12 Jan 2002 10:55:51
Message: <3C405C56.888F07A7@aol.com>
Dearmad wrote:
> >> However, there are a million ways to skin a cat...
The best way to skin this particular cat in Moray, since it is only a pipe in the
shape of a C, is to use a cylindrical bicubic patch object, scale it so that it
is long and thin, and then select each "ring" of the cylinder, and rotate and
translate into place.
Date: 12 Jan 2002 11:07:47
Message: <3c405f53$1@news.povray.org>
Thanks I will check that out.
"Jan Walzer" <jan### [at] lzernet> wrote in message
news:3c402f3b@news.povray.org...
jan### [at] lzernet
Jan
Walzer
