Is there a way to temporarily hide an object in Moray so its not part of the
rendering and not on the screen?
yes. visibility levels.
Current obsession: "Ballet pour ma fille."
http://www.applesnake.net
type "visibility" into the help file and read that- it'll explain
it in detail.
Thanks (duh on my part).
"Dearmad" <dea### [at] applesnake net> wrote in message
news:3C3E773F.8633F264@applesnake.net...
> it in detail.
we've all been there... believe me.
> > it in detail.
hi mitchell!
Dearmads visibility levels only changes the visibility of objects in
moray. if you want objects not to be rendered, you must uncheck the
render-checkbox of the objects.
alex
> of the
You read my mind. I was just trying to figure out how/where to control an
objects rednerness. Does each object have such a checkbox and where exactly
is it hidden?
thanks
Mitch
"Alex Wolff" <ale### [at] gmx de> wrote in message
news:3C40A82A.EF728E6C@gmx.de...
> hi mitchell!
> alex
> > of the
Hi Mitchell Waite, you recently wrote in moray.win:
> Does each object have such a checkbox and where exactly is it hidden?
It's on the Modify Tab of the object with the other flags (no_shadow,
etc). It's labelled "Export".
Note that export is only considered for top-level objects. Children
are always exported if parents are exported.
Also take a look at Layers for visibility stuff. Using Ctrl-1 toggles
layer 1 on and off.
- Lutz
email : lut### [at] stmuc com
Web : http://www.stmuc.com/moray
> layer 1 on and off.
that reminds me, how difficult would it be to give objects a variable detail
level?
something like, highest setting draws everything, medium draws only main
object and immediate child objects, almost lowest draws only the parent,
lowest gives you a bounding box?
PGP Public Key
Hi Rick [Kitty5], you recently wrote in moray.win:
> level?
The current architecture would make this a tad bit difficult.
Especially keeping the non-OpenGL viewport drawing....
- Lutz
