POV-Ray : Newsgroups : moray.win : soft shadows Server Time
13 Jun 2026 08:41:03 EDT (-0400)
  soft shadows (Message 1 to 10 of 16)
Subject: soft shadows
Date: 9 Jan 2002 16:13:37
Message: <3c3cb281@news.povray.org>
I have seen how you can apply soft shadows in povray with spot lights and
omni lights. Somebody can tell me how can I do the same in moray?
Thanks.
Antonio
Subject: Re: soft shadows
Date: 9 Jan 2002 17:03:18
Message: <3c3cbe26@news.povray.org>
news:3c3cb281@news.povray.org...
> Thanks.
> Antonio
Sorry Antonio, too much work here in Real Life to answer your last post.
I think the soft shadows with spot and point lights can be obtained using
fade_power and fade_distance.
To know how this modifiers work, you can take a look at the documentation
(look at povray docs also).
Good luck
Bye
Txemi Jendrix
tji### [at] euskalnetnet
http://www.geocities.com/txemijendrix
Date: 9 Jan 2002 18:40:42
Message: <3c3cd4f9@news.povray.org>
Txemi Jendrix <tji### [at] euskalnetnet> wrote:
: I think the soft shadows with spot and point lights can be obtained using
: fade_power and fade_distance.
  Not really. You need area_light for that.
Date: 9 Jan 2002 18:54:05
Message: <3c3cd81d@news.povray.org>
just use area lights
PGP Public Key
Date: 10 Jan 2002 03:41:34
Message: <3C3D4C83.368E007A@gmx.de>
another way is to use so many lights at *nearly* the same place that the
shadows seem to fade out smoothly. i found out that you will need
between 10 and 20 lights to create a smooth fade. no problem with the
moray duplicate-option!
and rendering seems to be much faster than with area lights.
alex
Date: 10 Jan 2002 07:29:13
Message: <3c3d8919$1@news.povray.org>
I can't really believe that ...
especially, if they are at the same position, how can the shadows become
smooth ?
if you distribute them a little bit, you do the same thing, as area_lights
do,
but a_l do more ... They don't need so much light_sources as they support
jitter and adaptive sampling ...
Note: The more lightsources you have, the slower your rendering will be ...
"Somehow what you suggest is like suggesting to add drills \ jan### [at] lzernet
to cars so you can drill for oil when you run out of fuel.  \
Sure you could do it, but it might not be the most practical >          Jan
solution." [Thorsten Froehlich in p.u.p]                    /        Walzer
Date: 10 Jan 2002 10:44:14
Message: <3C3DB6C6.5755CD9A@duratechindustries.net>
I agree that your render will be slower.  Also keep in mind that if your forget
to lower the
magnitude for each individual point light, your scene might be a bit brighter
than expected,
whereas an area light only has one magnitude value to worry about.
-Lawrence
> smooth ?
> do,
Date: 10 Jan 2002 10:51:18
Message: <3c3db875@news.povray.org>
Alex Wolff <ale### [at] gmxde> wrote:
: and rendering seems to be much faster than with area lights.
  This can't be true.
  You are probably creating a non-adaptive area light with 100 points and
comparing it with 10 individual point lights.
  Create the area_light with the same amount of points as your trick and
use adaptiveness (eg. adaptive 0, adaptive 1 or whatever is the smallest
number which gives a good result). The area_light should render a lot faster.
Date: 10 Jan 2002 14:35:59
Message: <MPG.16a6e8067e3bb22a989aa7@news.povray.org>
On 9 Jan 2002 18:40:42 -0500, Warp wrote...
Or you can use lots and lots of point lights or spotlights with
fade_power etc set.  I know you can 'cos i've done it when I got bored.
Bye for now,
     Jamie.
Date: 10 Jan 2002 19:40:23
Message: <3c3e3477@news.povray.org>
Jamie Davison <jam### [at] ntlworldcom> wrote:
:>   Not really. You need area_light for that.
: Or you can use lots and lots of point lights or spotlights with
: fade_power etc set.
  But why would you want to do so? area_lights do exactly that, but you
can use adaptive sampling in order to seed up the rendering.
