POV-Ray : Newsgroups : moray.win : Crashnig Moray by adding a simple cube Server Time
17 Nov 2025 19:21:42 EST (-0500)
  Crashnig Moray by adding a simple cube (Message 1 to 7 of 7)
Subject: Crashnig Moray by adding a simple cube
Date: 2 Jan 2002 11:22:18
Message: <3c3333ba$1@news.povray.org>
I have a terrain scene that renders just fine in Moray.
However if I add a simple cube and put any material on it then when I render
I get a Moray program crash.
If I export the pov file and render in povray it works fine.
How can I find out why Moray is crashing? (BTW my vertexes and edges show
69% aned 27%).
Mitch
Subject: Re: Crashnig Moray by adding a simple cube
Date: 3 Jan 2002 05:10:20
Message: <heb83u0f5hq55ke9n4v7gsuurho264qeck@4ax.com>
Hi Mitchell Waite, you recently wrote in moray.win:
> 69% aned 27%).
Send me the MDL file, I'll take a look. No idea why it would do
that.....
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
Date: 3 Jan 2002 10:34:00
Message: <e7u83uoo19oibvsq5rrmtjbqafnj4bckn7@4ax.com>
> 69% aned 27%).
Thanks for the scene.
Do your Vertex and Edge displays turn red? If so, then you have too
little memory reserved for them.
I needed to turn my edges up, since it was red. I have 210000 Vertices
and 84000 edges being displayed. Is this what you have?
My memory settings (View|Configuration|Advanced) are set to 290000 for
Vertices and 160000 for edges.
Either way, I can't crash it by adding new objects.... Maybe you can
send me a screenshot of the Advanced panel as mentioned above, it
could be that it's a very unfortunate combination of stuff...
- Lutz
Date: 3 Jan 2002 14:26:25
Message: <3c34b061@news.povray.org>
Lutz:
I have 20871 Vertexes and 83360 edges so we are close to agreement there.
I was seeing red in those status areas but increased my memory via the
Advanced Panel and the red went away.
My advanced panel is attached (its small so I hope its okay to send).
I notice the Program Error message occurs just as the ray tracing gets to
the beginning of the cube with the material called LED2.
thanks
Mitch
PS The Program Error says a log file is created but it does not say what the
name of that file is or where to find it. Perhaps if I looked at that it
would give a hint.
"Lutz Kretzschmar" <lut### [at] stmuccom> wrote in message
news:e7u83uoo19oibvsq5rrmtjbqafnj4bckn7@4ax.com...
show
> > 69% aned 27%).
> Regards,
> - Lutz
Download 'Advanced Panel.gif' (14 KB)
Preview of image 'Advanced Panel.gif'
Date: 6 Jan 2002 14:05:19
Message: <3c389fef@news.povray.org>
Any news on this issue Lutz. Also can you tell where to find the error log
in Moray so I can see if that sheds any light on the issue?
Mitch
news:heb83u0f5hq55ke9n4v7gsuurho264qeck@4ax.com...
show
> > 69% aned 27%).
> that.....
> - Lutz
Date: 7 Jan 2002 12:24:52
Message: <e9mj3uk173b52c5qtr07leabshlg7vj6t6@4ax.com>
No news. Since I can't reproduce it, I can only suggest you try
increasing the memory settings further. Does it also happen if you
create a sphere or another object? What about if you create the cube
first and then the heightfield?
Are you using OpenGL in any of the views, or are they all using Moray
drawing mode?
Moray doesn't generate error logs during normal operations. You can
try passing '-log' on the commandline and it'll dump some stuff, but
probably not anything that will help in this case.....
- Lutz
Date: 7 Jan 2002 12:36:21
Message: <m1nj3u0tve06kdcdse91t931q04usap0fq@4ax.com>
Can you also post a screenshot of the Render Options (Alt-F9) dialog,
please?
- Lutz
