POV-Ray : Newsgroups : moray.win : Export to POV? Server Time
13 Jun 2026 11:13:41 EDT (-0400)
  Export to POV? (Message 1 to 9 of 9)
Subject: Export to POV?
Date: 1 Jul 2001 14:55:32
Message: <3b3f7224$1@news.povray.org>
Is it possible to export a Moray scene to a POV file?
Subject: Re: Export to POV?
Date: 1 Jul 2001 16:39:29
Message: <MPG.15a99b4885ef8dfb989986@news.povray.org>
On Sun, 1 Jul 2001 11:56:10 -0700, Jason Jong wrote...
Yes.
Or were you after more info than that?
Press Ctrl-F9, and the corresponding .pov and .inc files will be exported
into your standard location (usually /moray for windows/povscn)
Bye for now,
     Jamie.
Date: 1 Jul 2001 16:42:26
Message: <3B3F8BD5.DF690895@debitel.net>
It's not only possible, that's the way moray communicates with povray.
Every file you render, you can find a pov-file in the povscn subfolder.
If you want to export a file without rendering it, press ctrl-f9. Then
you can find it in the povscn folder as well (if i recall right)
Arne Kleinophorst
Date: 1 Jul 2001 23:21:18
Message: <3b3fe8ae$1@news.povray.org>
"Arne Kleinophorst" <kle### [at] debitelnet> wrote in message
news:3B3F8BD5.DF690895@debitel.net...
Yes, that's correct.  The full path (assuming you're using the default
setup) is:
C:\Program Files\Moray For Windows\PovScn\[filename].pov
There is also an .INC file in the same directory with all your texture
information.
-Ian
Date: 12 Oct 2001 15:43:18
Message: <3bc747d6@news.povray.org>
Is there a way to make it left handed?
"Ian Burgmyer" <the### [at] hotmailcom> wrote in message
news:3b3fe8ae$1@news.povray.org...
> setup) is:
> information.
> -Ian
Date: 13 Oct 2001 08:52:53
Message: <r9egst8h9h7dkno8k0cph0av1sr4jbd0ih@4ax.com>
Hi Digger Mole, you recently wrote in moray.win:
No.
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
Date: 13 Oct 2001 10:48:34
Message: <3bc85442@news.povray.org>
> No.
can you not just do a numerical conversion at the point of export?
PGP Public Key
Date: 13 Oct 2001 10:56:49
Message: <3BC857A7.5F138260@pacbell.net>
> > No.
No.
Ken Tyler
Date: 13 Oct 2001 14:36:44
Message: <3bc889bc@news.povray.org>
Drat
That's all I have to say...
unless you took out the part that says to make right handed, and then put a
union around it and rotated or something like that
"Ken" <tyl### [at] pacbellnet> wrote in message
news:3BC857A7.5F138260@pacbell.net...
> > > No.
> No.
> Ken Tyler
