POV-Ray : Newsgroups : moray.win : plugin bug Server Time
13 Jun 2026 12:47:02 EDT (-0400)
  plugin bug (Message 1 to 7 of 7)
Subject: plugin bug
Date: 2 Jun 2001 15:06:05
Message: <3b19391d$1@news.povray.org>
Plugin bug-Scene file contains keys for unknown objects
This is the warning every time i open moray...what does it mean and how do i
stop it
Marc
Subject: Re: plugin bug
Date: 4 Jun 2001 04:01:40
Message: <62gmhtc3iql6asn091nutkq7jj197sq2f1@4ax.com>
Hi george ferguson, you recently wrote in moray.win:
> stop it
This is an error message from the animation plugin. It seems that the
scene file that is being loaded on startup has been incorrectly saved.
Try loading and saving it again.
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
Date: 10 Jun 2001 23:27:27
Message: <3b243a9f@news.povray.org>
"Lutz Kretzschmar" <lut### [at] stmuccom> wrote in message
news:62gmhtc3iql6asn091nutkq7jj197sq2f1@4ax.com...
do i
> > stop it
That seems to happen quite a bit, though...
Problem in 3.3?
-Ian
Date: 11 Jun 2001 10:30:17
Message: <3B24D6FF.9C106E29@mitre.org>
Not a problem in 3.3.  Problem in anim plugin (actually, not a problem
since it is just a warning message).
Typically this occurs when you have been working with a scene, delete
object(s), save the file.  There can be problems with getting all of the
keyed information to disappear before the save.  On load, if you saw
that message, all that has occured is that the extra key information
(for the deleted object) has been discarded.
I will likely just silently load the .mdl file in the future.
Xander
> do i
> > > stop it
> Problem in 3.3?
> -Ian
Date: 11 Jun 2001 14:12:36
Message: <3b250a14$1@news.povray.org>
"Alexander Enzmann" <xan### [at] mitreorg> wrote in message
news:3B24D6FF.9C106E29@mitre.org...
Ah, alright.
Oh, alright.
But what if you don't use any keys?
That should work, as there's not really a problem with the scene when it's
loaded.
-Ian
Date: 12 Jun 2001 16:20:15
Message: <3B267A89.E3F71A87@mitre.org>
Ian Burgmyer wrote:
> Oh, alright.
If you are using the Anim plugin, you will get at least one key forced
on the first frame.   It's just the way it works...
Xander
Date: 24 Jun 2001 17:26:43
Message: <3b365b13@news.povray.org>
news:3B267A89.E3F71A87@mitre.org...
Oh, okay... *nods*
-Ian
