3DWin. Import 3DS file, export RAW file. Open in Moray. Whoops,
CAN'T open in Moray, it has to be converted to UDO first! 3DWin.
Import RAW file, export POV/UDO files. Open in Moray. Good.
Render. CRASH-OLA. POV freeze, giving error about inability to open
thisorthat_m.inc. It's right there! Looks fine. WTF?
Tim Cook
Version: 3.12
Are you using POV-Ray v3.5?
If so, do you have the security settings set properly in POV-Ray v3.5?
Ken Tyler
> POV-Ray v3.5?
Yes and yes.
Tim Cook
Version: 3.12
Hi Timothy R. Cook, you recently wrote in moray.win:
Right where? Is it in the same path as your scene POV file? Or is it
in a library path?
- Lutz
email : lut### [at] stmuc com
Web : http://www.stmuc.com/moray
> in a library path?
In the same path as the POV file.
Tim Cook
Version: 3.12
> CRASH-OLA.
Moray crashes? Freezes?
> thisorthat_m.inc.
If POV freezes how can you see the error?
Does the file render outside of Moray?
- Lutz
> > CRASH-OLA.
> > thisorthat_m.inc.
Actually it's POV that freezes right after giving the can't read
error, causing Moray to become confused and sluggish (I've
encountered the 'POV-crash-confusing-Moray' problem elsewhere,
but don't remember what I was doing...)
Tim Cook
Version: 3.12
see GTTree Plugin post above
Best Regards
Keith
"Timothy R. Cook" <tim### [at] scifi-fantasy com> wrote in message
news:3C76D139.76D50353@scifi-fantasy.com...
> > > CRASH-OLA.
> > > thisorthat_m.inc.
> Tim Cook
> http://empyrean.scifi-fantasy.com
> -----BEGIN GEEK CODE BLOCK-----
> Version: 3.12
> GFA dpu- s: a?-- C++(++++) U P? L E--- W++(+++)>$
> N++ o? K- w(+) O? M-(--) V? PS+(+++) PE(--) Y(--)
> PGP-(--) t* 5++>+++++ X+ R* tv+ b++(+++) DI
> D++(---) G(++) e*>++ h+ !r--- !y--
> ------END GEEK CODE BLOCK------
