POV-Ray : Newsgroups : moray.win : grouping problems... Server Time
17 Nov 2025 19:23:43 EST (-0500)
  grouping problems... (Message 1 to 5 of 5)
Subject: grouping problems...
Date: 16 Jan 2002 12:40:31
Message: <3C45BB60.3090800@exmail.de>
I have a little problem with grouping. I never run into it till now,
cause i was not in need of it:
long time ago i modelled an object in moray, consisting of csg's and
differences.
Now, i'm working on a new scene and i wanted to import the old object.
So far, it works. But it would be nice to have the old object in a
group, so that i can select it with a single mouse click. I grouped it
(with all the csg's and differences) but pov runs into an error during
parsing, caused of the difference partial object. Can anyone help me?
Version with grouping in Moray
#declare cube = difference {
   superellipsoid { // cube_frame
     <0.1, 0.1>
     material {
       T_Chrome_4A
     scale 4.4
   object { // Cube_frame_diff2 -> Cube frame diff1
     Cube_frame_diff1
     rotate -90.0*z
   object { Cube_frame_diff1 }
   object { // Cube_frame_diff3 -> Cube frame diff1
     Cube_frame_diff1
     rotate -90.0*y
   material {
     earthmap
   rotate <-45.0, -35.259998, -10.0>
   translate  12.4*z
Version without grouping in Moray
difference { // cube
     <0.1, 0.1>
     material {
       T_Chrome_4A
     scale 4.4
     Cube_frame_diff1
     rotate -90.0*z
     Cube_frame_diff1
     rotate -90.0*y
   material {
     earthmap
   translate  12.4*z
P.S.: maybe not the right newsgroup, i don't know...
best wishes,
Robert
Subject: Re: grouping problems...
Date: 17 Jan 2002 03:45:22
Message: <en2d4u0pmjm2viufeulkv50la95cr5p9qm@4ax.com>
Hi Robert, you recently wrote in moray.win:
What is the error message? Maybe you can send me the MDL file.
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
Date: 17 Jan 2002 11:12:41
Message: <3C46F849.40308@exmail.de>
Hi Lutz,
  the error message is:
File: E:\Programme\Moray For Windows\PovScn\ferrocube_crash.pov  Line: 161
#declare cube <----ERROR
Parse Error: Expected 'undeclared identifier', cube found instead
Returned from renderer with error status
i had to delete some objects (textures) to make the file smaler, but the
problem remains. So you can try the attached mdl-file.
By the way,
is there coming up a solution with the camera problem? (I'm using moray
3.3a + pov beta10).
many thanks for the quick reply!
best wishes,
Robert
Download 'ferro_crash.zip' (6 KB)
Date: 17 Jan 2002 13:02:17
Message: <fb4e4ugeimbfa67763p4qip4t2e24mk1o4@4ax.com>
Wait a second. Isn't cube a reserved word? Try renaming it to mycube
or something and see if that solves it.
- Lutz
Date: 17 Jan 2002 13:33:22
Message: <3C47193F.7020204@exmail.de>
Many thanks!
I didn't noticed that. Renaming works!!
best wishes,
Robert
> - Lutz
