POV-Ray : Newsgroups : moray.win : material proxies Server Time
13 Jun 2026 12:38:19 EDT (-0400)
  material proxies (Message 1 to 3 of 3)
Subject: material proxies
Date: 12 Mar 2001 11:52:56
Message: <3AACFEE8.C215262F@ucdavis.edu>
i think mine are broken.  the only circumstances under which i have been
able to see the material proxies is with image maps.  of course, they
are turned on, and they should be bright green according to the
interface scheme i'm using.  but when i alt-t to select the material,
and then translate it around, nothing on the screen moves to indicate
where the material's origin is.  any ideas? lutz?
Subject: Re: material proxies
Date: 13 Mar 2001 05:39:32
Message: <h9uratsmnvk9dns90ck3m639ho998vidjd@4ax.com>
Hmmm, they work fine here, at least for checker and hexagon pigments.
Note that not all texture types have proxies. They should be available
for wood, checker, hexagon, image_map and gradient (i may have missed
some).
Are you not seeing proxies with any of these? And they have been
assigned, right?
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
Date: 13 Mar 2001 17:12:08
Message: <3AAE9B38.BC5CEBED@ucdavis.edu>
> some).
maybe that's my problem.  i was just trying to do a cylindrical
texture.  i had hoped there would be a proxy to show me the center and
orientation, as well as the 'edge' of the texture.  but if you don't
have proxies set up for all texture types, i'm barking up the wrong
tree.  :(  i'll just have to keep guessing until i get it lined up right
i suppose. :(
