Hello all,
I know this may sound like a simple question, but.... What is a
good way to make a curved doorframe/archway (non 90degree angles) in Moray?
Any help will be much appreciated.
Josh
On Wed, 25 Oct 2000 01:05:56 -0400, Warheart wrote...
> Hello all,
The quick answer is CSG.
The long answer is - What exactly is the shape of the frame you want to
make? As a general case, you can link together cylinders and sections of
tori to make a very basic shape, or you can get much more involved.
Bye for now,
Jamie.
Jamie Davison wrote in message ...
>> Hello all,
Moray?
Well, think of what I am trying to make as an upside down U. Plain as that.
Now what is a 'tori' ? Again, sorry for what may come across as a simple
question =)
Josh
> question =)
A tori is a torus. You can cut a torus in half using a csg operation.
The remainer is an arch shape. Attach a cylinder to either end and you
have an archway. Kind of primitive but it works.
Ken Tyler
>question =)
The plural of 'torus.'
Peter Popov ICQ : 15002700
Personal e-mail : pet### [at] usa net
TAG e-mail : pet### [at] tag povray org
> question =)
> Josh
In that case i'd use a transitional sweep. Maybe you should try it out.
Arne Kleinophorst
Ken wrote in message <39F7C559.38C45196@pacbell.net>...
that.
>> question =)
Well, I have attempted to do this. Now what exactly do I have to do in order
to cut the torus in half? I have attached cylinders to both sides of it and
tried merge, difference, interesection, and union but cant seem to come up
with the desired effect. Thanks in advance for your help!
Josh
you've got to first cut the torus using a box or a plane by
differencing, then add the cylinders to the result using union. have
you looked at the tutorials in the help file? they cover how to do this
stuff.
> that.
> >> question =)
> Josh
On Thu, 26 Oct 2000 11:06:37 -0400, Warheart wrote...
> that.
> >> question =)
Tori is how I spell the plural of torus.
It's also (IIRC) the first name of a female musician a friend of mine has
a certain attraction for (Tori Amos)
Create a torus.
Rotate x=90 (type 90 into the x rotation box in the modify tab)
Translate z=5
Create a Cube.
Scale x=3 and z=2
Translate z=7
Create a CSG (union because all CSG operations start as unions in Moray)
Click Add in the Modify tab.
Add the Torus and Cube.
Select intersection as the Operation type.
Hit evaluate.
Create a cylinder.
Scale it to x=0.5 y=0.5 z=5
Translate it to x=1.5
Make another cylinder
Scale it the same as the last one.
Translate it to x=-1.5
Create another Union, and add the previous union and the two cylinders to
it.
Leave the operation type as Union.
Now, if you select the union, you can move the entire (rather crude)
doorframe around your scene.
Did this make any sense?
Sorry for the delay, but I tend to check my news once a day and read it
offline, then I just drop on quickly to upload any posts.
Bye for now,
Jamie.
