Request for Enhancement: I would like to be able to control,
either at the Moray scene level, or at the Moray global level,
text output options. The POV options I would like to control are:
Debug_Console
Statistics_Console
Warning_Console
Render_Console
(These are located in the POVRay.ini file, but Moray writes its
own scenefile.ini file, which overrides the POVray.ini file.)
OR, be able to tell Moray not to write a scenefile.ini file, so
the POVRay.ini file will be used instead for previews.
See my Free stuff page. It compares free website providers, and
lists free internet access providers.
http://www.crosswinds.net/~robertsc/free.htm
Win98 help file loaded with hints and tips, including securing a
Win 95/98 PC in a classroom setting. VB4 help file with lots of
code and hints.
At http://www.crosswinds.net/~robertsc/
Hi Chuck Roberts, you recently wrote in moray.win:
Moray copies all these from the [POVWin INI] section of MORAY.INI. If
you want to always have them in a certain state, edit them there.
Alternatively, you can delete those four from MORAY.INI and add them
to the POV master INI.
- Lutz
email : lut### [at] stmuc com
Web : http://www.stmuc.com/moray
Does Moray copy these file every time it is started? Or only when
it is installed and first run?
code and hints.
I'm not sure what you mean by "these file"? Moray copies the text
lines in said section of MORAY.INI to the SCENEFILE.INI it generates
on every export or render.
In the process it changes those lines that correspond to settings in
its Rendering Options dialog to the settings made there, or adds the
settings if they are not in MORAY.INI.
- Lutz
