POV-Ray : Newsgroups : moray.win : assumed and display gamma and other settings Server Time
18 Nov 2025 04:55:50 EST (-0500)
  assumed and display gamma and other settings (Message 1 to 6 of 6)
Subject: assumed and display gamma and other settings
Date: 21 Jul 2000 15:55:54
Message: <3978AA90.88A54284@yahoo.com>
in moray, i only find a spot to change the assumed gamma, but it looks
like moray uses this number to set both display and assumed.  i want to
set each differently.  is there a way to do this in moray or must i do
it by hand?  also, is there a way to change the default numbers in the
dialog boxes especially for radiosity?  if i set my settings and then
just save over the 'new' scene (the one loaded when you click on the new
button) will that do the trick?
Subject: Re: assumed and display gamma and other settings
Date: 21 Jul 2000 16:54:09
Message: <MPG.13e2bf4b1f58336d989762@news.povray.org>
On Fri, 21 Jul 2000 12:54:56 -0700, ryan constantine wrote...
Maybe I'm misunderstanding, but I thought that diplay gamma was
determined by your particular hardware settings?
Bye for now,
     Jamie.
Date: 21 Jul 2000 21:49:17
Message: <3978FD51.736CEE5B@yahoo.com>
it is an ini file setting, and is based on the results you get from
running the po gamma test (a text file with instructions on how to use a
gif image test).  the assumed gamma is what the image thinks the gamma
is.  the way i understand it, pov checks both and then does calculations
so the image comes out right.
> Bye for now,
>      Jamie.
Date: 22 Jul 2000 08:01:18
Message: <MPG.13e39b70f4793a63989765@news.povray.org>
On Fri, 21 Jul 2000 18:48:01 -0700, ryan constantine wrote...
<snip>
Well, you can tell I do my POVing through Moray, can't you :)
Bye for now,
     Jamie.
Date: 23 Jul 2000 02:50:04
Message: <da3lns8hp8oak1t88bosq5lktit1r1sd8q@4ax.com>
Hi ryan constantine, you recently wrote in moray.win:
Actually, it doesn't. Moray only exports the assumed_gamma in the POV
file. The display_gamma in the scenes INI file comes from the settings
that are specified in MORAY.INI. Moray copies all the POV settings
from MORAY.INI to the scenes INI file and then replaces those that it
sets itself (like width, height, etc).
> i want to set each differently.  is there a way to do this in moray ....
Yes. Edit MORAY.INI and set the display_gamma value to what you need.
> if i set my settings and then just save over the 'new' scene
I think so. Load MorayStart.mdl or the file specified under
View|Configuration|Moray|Name of scene to load at startup. Edit the
parameters and save. That way they should be loaded the next time you
click on New.
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
Date: 23 Jul 2000 15:51:10
Message: <397B4C79.5B7FB6D@yahoo.com>
aha! thanks lutz.  was this in the docs and i missed it?
> click on New.
> - Lutz
