POV-Ray : Newsgroups : moray.win : galaxy plugin Server Time
18 Nov 2025 04:55:50 EST (-0500)
  galaxy plugin (Message 1 to 2 of 2)
Subject: galaxy plugin
Date: 9 Jul 2000 16:24:51
Message: <3968DF3F.C2F4FC54@yahoo.com>
if i set the scene ambient value to 0, will stars disappear?  i want to
use radiosity in a scene (there are enough objects close to each other
to get radiosity interaction), but i usually set ambient to zero when i
do.  also, i was interested in knowing the mechanics of the plugin
itself.  are star just disks?  are they in a union?  would a union of
triangles (or as a mesh) that approximate circles be better and faster?
Subject: Re: galaxy plugin
Date: 9 Jul 2000 19:58:11
Message: <39691193@news.povray.org>
The star textures have ambient set to 1 and all other finish values to 0, so
they should work OK even if you use a different default ambient value.
Internally each star is created as a single triangle.  However, these are
not placed in a mesh (because to do so would require creating separate
textures for every star).  Instead, they are unioned in a group of 50
triangles.  This group is then used to populate the entire sky with stars -
after a lot of experimentation I've found this method yields by the far the
fastest and most efficient results.
