the ability to select Multiple objects when adding to CSG and groups...
On Sun, 25 Jun 2000 11:37:27 +0000, Psychomek wrote...
I've already asked for that, but for the moment, using Shift-Left Click
can speed up the process.
Besides, given what Shift Clicking does at the moment, I'm not sure how
easy it would be to implement the usual Windows selection methods.
Although a drag box and Ctrl Selection may be a workable alternative.
Bye for now,
Jamie.
THANKS!!!!! this will speed it up GREATLY! i have about 2000 stacked cubes
that needed added to a csg.... it was SLOW going as click enter....
> Bye for now,
> Jamie.
"Don't give fish to the beggar, teach him how to fish"
> > Bye for now,
> > Jamie.
most beggars i run into don't ask for and wouldn't want fish.:)
On Mon, 26 Jun 2000 05:59:55 +0000, Psychomek wrote...
Don't thank me, I found that little trick out off this exact NG a while
ago. I think I need to read the help files again :)
And as for 2000 cubes.... Ouch!
Bye for now,
Jamie.
> i have about 2000 stacked cubes that needed added to a csg....
Just a quick question: How did you create the 2000 cubes? If you used
the Duplicate Dialog here's a tip for the future
First create the CSG or Group that you want the cubes to be in. Then
create the first cube (the one you're going to copy). Add this cube to
the CSG/Group. Select the cube and position it as you need, then call
the Duplicate function. In the dialog, enable the "Attach To Same
Parent" checkbox. Then press OK to create the copies. They are
automatically add to the CSG/Group.
The problem with multiple selection is that the control is a tree
control, not a list control. So if you select an subobject, it is
moved inside the tree. It starts getting ugly when you have to make
sure that a parent is not selected along with a child, etc.
An alternative could be to make it a listbox and to only display
top-level objects. It would be easy to allow multiple selection in
this listbox. Would that be useful?
- Lutz
email : lut### [at] stmuc com
Web : http://www.stmuc.com/moray
I would like that too. Be sure to implement shift-click to select
a range of objects too.
See my Free stuff page. It has compares free website provider,
and lists free internet access providers.
http://www.crosswinds.net/~robertsc/free.htm
Win98 help file loaded with hints and tips, including securing a
Win 95/98 PC in a classroom setting. VB4 help file with lots of
code and hints.
At http://www.crosswinds.net/~robertsc/
On Tue, 08 Aug 2000 12:50:17 -0400, Chuck Roberts wrote...
Shift Click is already implemented in the CSG Adding window, it adds the
Item that is shift-clicked to the CSG without requiring you to hit the
Add Object button.
Bye for now,
Jamie.
> You can do it manually IIRC.
I know I can do it manually, it would just be nice not to have to...
PGP Public Key
On Sun, 15 Apr 2001 16:58:33 +0100, Rick [Kitty5] wrote...
How often do you have to do it though? Or is another piece of your
software reconfiguring it regularly?
And for some reason my news browser seems to have attached your reply to
a completely diffeernt thread...
Bye for now,
Jamie.
