I tried making an image with a bump map today.
If the image file is in the \Moray\Maps directory, things work fine. If
it is in any other directory, it states that the file cannot be found.
If I use the same image as an imagemap, it has no problems, no matter
where the file is located.
Does the searchpath for bumpmaps not work in the same manner as for
imagemaps?
Simon
Hi Simon de Vet, you recently wrote in moray.win:
> imagemaps?
It works in the same manner, but does not use the same Search Path.
Simply do a Check Scene and point it to the correct directory when
prompted.
- Lutz
email : lut### [at] stmuc com
Web : http://www.stmuc.com/moray
