Hi All- I'd love to be able to 'export selected' (render menu) and have only
the selected object, or light or camera update in the corresponding POV
files.
-Pascal
Maybe, even better would be a "Layer Editor" window that is similar to AutoCAD.
From that window you could possibly change the visibility & color of objects in
Moray, lock or freeze objects and set the export option for each object -
provided that Moray supports these features in the future.
> files.
> -Pascal
There is a visibility control for each object.
Mike
wk: mik### [at] pyxis com www.pyxis.com
hm: mwe### [at] sciti com www.geocities.com/mikepweber
"Tony Vigil" <tvi### [at] emc-inc com> wrote in message
news:38ECD661.31CFEDB3@emc-inc.com...
AutoCAD.
objects in
only
> > files.
> > -Pascal
Hi Tony Vigil, you recently wrote in moray.win:
> Moray, lock or freeze objects ...
What's the difference between lock and freeze?
That gets to be a nightmare once you start allowing subobjects to not
be exported, which is why currently only top-level objects can be made
to not be exported.
- Lutz
email : lut### [at] stmuc com
Web : http://www.stmuc.com/moray
Hi Pascal Golay, you recently wrote in moray.win:
> files.
Why? Does the export take so long?
If you're wanting to render parts of the scene only, use the "Export"
checkbox on top-level objects to stop them from being exported when
you render.
- Lutz
Lutz Kretzschmar wrote in message ...
only
>> files.
>you render.
Yes, thanks, that's what I do when I want to render the parts of the scene.
But for example, if I make changes to a light in Moray, and want to export
just that updated light to the POV file it would make things much easier
because I would not overwrite objects that were edited in the POV file. The
thing I'm after is keeping a POV file intact but updating certain parts of
it taking advantage of the Moray GUI. It works well with the Material editor
because I can copy and paste from the text window on the lower right. If
there were a similar for objects, cameras, lights, etc that would be great
and work just like an export selected function.
As it is, I save the the POV file that Moray exports right away under a new
name and find the changes exported to the original POV file and copy and
paste to the renamed pov file, if you see what I mean.
-Pascal
search this newsgroup for messages from lutz. he told me how to add a
comment to a pov or inc file so moray won't overwrite parts of it. it's
late, otherwise i would look it up for you.
> only
> >> files.
> >you render.
> -Pascal
Right, I remember that- but perhaps I misunderstood- I thought it was for
protecting materials only, not geometry and lights and things- I'll go back
and re-read it...my head is a bit full of all this stuff and I'm sure i'm
spinning my wheels in some respects. Thanks.
-Pascal
ryan constantine wrote in message <38ED5F8F.C700BC42@yahoo.com>...
have
>> only
POV
>> >> files.
>> >you render.
scene.
export
The
of
editor
great
new
>> -Pascal
