POV-Ray : Newsgroups : moray.win : image mapping experts out there? Server Time
10 Jun 2026 00:51:30 EDT (-0400)
  image mapping experts out there? (Message 1 to 6 of 6)
Subject: image mapping experts out there?
Date: 21 Feb 2000 00:07:56
Message: <38B0D89A.2518709@trilobyte.net>
Okay, I was just wondering if there is any way to somehow set a certain
color of an image map to "transparent", as in the case of placing an
image on a window of a store, or an etching on a wine glass.  I thought
it was possible with pigmentmaps somehow, but I'm lost.  Thanks.
Ben Hamatake
Subject: Re: image mapping experts out there?
Date: 21 Feb 2000 00:21:16
Message: <38B0CB00.B2BEB26F@pacbell.net>
> Ben Hamatake
I do not know if this is possible with Moray but there is a way to
do this in POV-Ray itself...
*IF* you use a palleted 256 color 8 bit image (such as the gif format)
you can specify a filter amount for a particular color pallet number.
For example if your image contained White areas and the pallet number
in your gif image for White were 255 then you could specify a filter
or transmit amount for that pallet number using the following syntax -
 image_map { gif "your_image.gif" filter 255, 1 }
The first number is the pallet number of the color you want to filter
and the second number after the comma is the amount of filtering you
want added to that color. You can use any filter amount from 0 - 1.
This method does not work with images that are not a palleted type
such are 24 bit .tga images.
Another method is to use the .png format that uses alpha channels
specified in the image itself and then you can instruct POV-Ray to
use the alpha channel for the image map. I don't have an example
handy for this method but you can read up on it in the POV-Ray
documentation. This method has the benefit that you can use images
with a greater color depth but requires that you pre-process the
image you plan to use i.e. you must save the image with alpha
channels enabled for the color you need filtered.
Date: 21 Feb 2000 04:14:29
Message: <38b100f7.2017781@194.174.214.110>
Hi Ken, you recently wrote in moray.win:
Yes, it sure is.
Ben, as Ken said if the image is 256-colors and you know which index
is the one you want to have transparent, you can make that index
filter 1 by selecting the imagemap node that you added and in the
dialog click on Add in the Filter section, select the index and set
filter to 1.0.
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
Date: 21 Feb 2000 06:10:21
Message: <38B11CD1.AAF5740@pacbell.net>
> Yes, it sure is.
> filter to 1.0.
Just curious,
Will Moray allow you to set more than one palette index ?
In Pov you can set multiple indexes.
For example:
             filter   255, 1
             filter   105, 0.5
             transmit  85, 1
Date: 21 Feb 2000 08:43:10
Message: <38b140ee@news.povray.org>
> Just curious,
> For example:
> pigment {
>              filter   255, 1
>              filter   105, 0.5
>              transmit  85, 1
Yes, Moray allows it in the Material Editor / Imagemap panel.
Amedeo
Date: 21 Feb 2000 09:58:28
Message: <38b152b2.1330259@news.stmuc.com>
Yes, and it also supports the "all" modifier. Texturing support is
pretty much 100%. "Pretty much" because I have not tried every
possible combination<g>. But there is nothing that we knowingly left
out.
- Lutz
