POV-Ray : Newsgroups : moray.win : Glowing Server Time
10 Jun 2026 08:08:37 EDT (-0400)
  Glowing (Message 1 to 7 of 7)
Subject: Glowing
Date: 17 Jan 2000 15:34:15
Message: <38837cc7@news.povray.org>
Hi there
Is there any possibilitie to create a great looking glowing effect?
Thanx
Subject: Re: Glowing
Date: 17 Jan 2000 15:51:40
Message: <388380D9.11975049@student.kuleuven.ac.be>
In plain Moray/POV-Ray it's not very easy (but possible, using
media).  But if you use a paint-program, like Paint Shop Pro, you can
add glows like this:
Render your image twice: once just the image, once with everything
black except the object that needs to glow (make it rgb 1 ambient 1
and remove the light_sources).
(I assume you use PSP5) Open both images.
Make a mask of the b/w-picture and save it to alpha-channel.
In the other image: make a new lighten-layer (or how is it called, a
layer that never removes a color, only adds color?) and paint it with
the color you want the object to glow.
Load the mask from the b/w-image-alpha-channel you just created (into
the new layer, of course).
You should have a glow around the object now.
It's not a very fast technique, but I'm sure it can be automized.
After all, you only push some buttons.
ZK
Jens Kleen wrote:
> Hi there
> Thanx
Date: 17 Jan 2000 16:18:16
Message: <38838833.C4C0D21C@t-online.de>
Jens Kleen wrote:
> Hi there
> Thanx
It depends on what you want to make glow...
Karl
Date: 18 Jan 2000 10:05:55
Message: <38848152.8C28C35E@student.kuleuven.ac.be>
Sorry, I forgot 3 steps:
-before you use the mask, you should first make a selection based on
the alpha channel (which is the same as the mask).  Then you should
feather it, save it to the alpha channel and reload it as a mask on
the glowing-layer.
ZK
> ZK
> Jens Kleen wrote:
> > Hi there
> > Thanx
Date: 18 Jan 2000 11:09:17
Message: <3884902d@news.povray.org>
Thanx
I will try it in my next Picture.
Date: 23 Jan 2000 09:12:03
Message: <388B0C82.9ADCDAE4@istar.ca>
Could you post a pair of images in p.b.i? I'd like to see how this
works...
Date: 23 Jan 2000 13:16:19
Message: <388b4573@news.povray.org>
Simon de Vet <sde### [at] istarca> schreef in berichtnieuws
388B0C82.9ADCDAE4@istar.ca...
> works...
Shouldn't be a problem.  I'll work on it tonight. You can expect it in a few
days.
ZK
