Hi all, I just recently discovered the joy Moray and POVray within the last
month. Right now I am attempting my first scene, and that is a snowman
complete with pipe, hat, carrot nose and twigs for arms. My question is: Is
there a way I can make my scene have 'snowflakes' or more or less the
illusion of snowflakes (after all it IS a snowman) ? Thanks in advance!
Josh
> Josh
I have had pretty good success creating the illusion of snow by placing
a plane between the camera and the rest of the scene. For the texture of
the plane use a granite pigment with clear areas and white areas in the
color map. The noise function in the granite pattern will help to create
a random snow flake noise pattern for you. A little playing and you should
find something that works.
Ken Tyler - 1300+ Povray, Graphics, 3D Rendering, and Raytracing Links:
why not try designing a snow flake - just one - small and simple - 100% sold
and fast to render, and fast for moray to manipulate a lot of them, place it
in a group, then create lots of references under the same group parent,
bingo - real snow
and with the anim plug - a doddle to animate
put some fog in you scene and you dont need that many
"Warheart" <For### [at] it com> wrote in message news:38782b78@news.povray.org...
last
Is
> Josh
Rick <pov### [at] dial pipex com> wrote:
: why not try designing a snow flake - just one - small and simple - 100% sold
: and fast to render, and fast for moray to manipulate a lot of them, place it
: in a group, then create lots of references under the same group parent,
: bingo - real snow
I think that it's not a trivial task to place objects in random locations
in moray currently.
> Josh
I once solved the problem by taking a font with a snowflake and making a
text object with it. I guess its the "T" in the "WinDings" font. But of
course this is not ideal if you want loads of snowflakes. It will slow
down, use memory ...
Karl
