POV-Ray : Newsgroups : moray.win : Q: memory settings in configuration dialog Server Time
18 Nov 2025 14:35:51 EST (-0500)
  Q: memory settings in configuration dialog (Message 1 to 5 of 5)
Subject: Q: memory settings in configuration dialog
Date: 21 Dec 1999 18:12:40
Message: <38600968@news.povray.org>
 I am trying to get moray to act a little snappier. I have 256Mb RAM and run
winNT4. What should I assign for vertcal and horizontal settings?
thanks,
mike
Subject: Re: Q: memory settings in configuration dialog
Date: 22 Dec 1999 05:15:06
Message: <3861a43a.7590905@194.174.214.110>
Hi michael mccue, you recently wrote in moray.win:
Vertical and Horizontal settings? What's that?
Below is a copy of a message in an earlier thread about optimizing the
redraw speeds.
- Lutz
The two redraw numbers on View->Configuration->Advanced are the key to
getting Moray's redraw going optimally on your system.
To optimize the redraw do this (use Alt-O, Ctrl-Shift-Tab to get to
the dialog):
-Set the "Minimum number of lines to draw before refreshing" setting
and the "Maximum number of lines to draw before refreshing" setting to
the same number (say 4000).
- Click OK and zoom and pan a 2D viewport.
- If it feels snappy go back and increase the numbers by 1000. Ignore
the total redraw time. Repeat until .....
- You will notice that at some point the view will start lagging
behind the mouse movements. You want to find a point where this is not
quite noticeable to you.
- Now increase the "Maximum...." number to control the total redraw
time for the scene. For example, try setting it to 100000. You will
see that the view is still responsive while panning and zooming, but
once you stop panning and hold the mouse still, the redraw finishes in
very few "steps". If you move the mouse during the redraws there will
be a lot more steps.
The way that it works is that Moray draws the minimum lines into an
off-screen buffer and will then show that buffer on the screen (that's
what the "Minimum" number controls). After that Moray will check to
see whether you are moving the mouse and if you aren't it will draw
the "Maximum" number of lines to the off-screen buffer and will then
show that. If you move the mouse, only the "Minimum" amount is drawn.
While attempting to draw the "Maximum" amount, Moray will check the
mouse every "Minimum" lines.
I have my settings at 10000 and 100000. My benchmark scene has 241300
edges and it redraws a single view in about a second (PII/266, 128MB)
and all four views in about 4 seconds if I keep the mouse still and 6
seconds if I move it.
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
Date: 22 Dec 1999 13:37:23
Message: <386219e5.1007468@194.174.214.110>
Hi michael mccue, you recently wrote in email:
I think what you mean is the memory for the vertex list and for the
edge list. Moray stores vertices (points) and edges (connection
information) of the wireframes. For speed these are kept contiguous in
memory.
> The default figures of 8000 Kb and 4500 Kb seem low with the 256 Mb
> available but maybe I am missing something.
The numbers are not directly related to available or installed memory.
As long as the indicators in the status bar (V:xxxx yy% and E:zzzz
ww%) are not red and are below 90%, you're fine. For larger scenes,
you may need to increase these numbers until the indicators are no
longer red. Moray will still run fine even if they are red, but parts
of the wireframe will be missing, since there is not enough memory to
store all vertices and edges.
It is a bad idea to make these lists larger than they need to be,
since anything that is not used is wasted (but allocated) memory which
POV-Ray could be utilizing to render the scene.
- Lutz
Date: 23 Dec 1999 23:35:39
Message: <3862f81b@news.povray.org>
Hi Lutz,
 Sorry to ask stupid questions but I am very new to this and I have very
little feel for how the programs work when working properly. Thanks for
taking the time to explain.
Best Wishes,
mike
Lutz Kretzschmar <lut### [at] stmuccom> wrote in message
news:386### [at] 194174214110...
> memory.
> - Lutz
Date: 24 Dec 1999 06:54:37
Message: <38635efd@news.povray.org>
just remeber, that after you have twaeked em up for a large scene, you may
want to turn em back down again, after all more ram for POVray is allways a
good idea :)
"michael mccue" <mik### [at] harmoniccyclecom> wrote in message
news:3862f81b@news.povray.org...
> Hi Lutz,
> Best Wishes,
> mike
> > memory.
> > - Lutz
