POV-Ray : Newsgroups : moray.win : udo's Server Time
10 Jun 2026 08:03:05 EDT (-0400)
  udo's (Message 1 to 4 of 4)
Subject: udo's
Date: 27 Nov 1999 03:19:08
Message: <383F93A0.9D9F95CA@t-online.de>
I have a mesh and want to import it into moray. it worked the first
time, I saved the moray-file but 1 day later when I opened the file
again and wanted to render it from moray, there was the message (in the
povray-window):
object {
NONAME <-- ERROR
ges1.pov:93 error: object expected but undeclared identifier 'NONAME'
found instead
I used 3Dwin (import raw, export POV-RAY3 Moray (*.inc,*.udo). Then I
imported it into Moray (create udo). I have povray 3.1g and moray 3.1.
thanks
Subject: Re: udo's
Date: 27 Nov 1999 07:01:02
Message: <383fc7b0.2562614@194.174.214.110>
Hi christof schuler, you recently wrote in moray.win:
> time, I saved the moray-file ...
Did you render it that first time and did that work?
> object {
> NONAME <-- ERROR
> found instead
Can you post the first 20 lines of the UDO file and the first 20 lines
of the INC file, please?
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
Subject: Re: udo's
Date: 27 Nov 1999 07:37:22
Message: <383FD025.1E12C471@t-online.de>
inc-file
#declare NONAME = mesh
	triangle { < -48.000000,66.772050,99.707040 >, <
-48.000000,64.005300,98.835140 >, < -48.000000,65.105780,100.803000 >}
-48.000000,65.678620,97.731170 >, < -48.000000,64.005300,98.835140 >}
	triangle { < -48.000000,115.240800,-33.459780 >, <
-48.000000,114.668800,-35.370360 >, < -48.000000,112.560900,-34.570290
	triangle { < -48.000000,113.133100,-32.649020 >, <
-48.000000,115.240800,-33.459780 >, < -48.000000,112.560900,-34.570290
	triangle { < -48.000000,110.648800,40.272870 >, <
-48.000000,112.065300,42.911290 >, < -48.000000,112.763100,41.042420 >}
	triangle { < -48.000000,113.429800,39.162200 >, <
-48.000000,110.648800,40.272870 >, < -48.000000,112.763100,41.042420 >}
-48.000000,111.318600,38.382790 >, < -48.000000,110.648800,40.272870 >}
	triangle { < -48.000000,114.065000,37.271690 >, <
-48.000000,111.318600,38.382790 >, < -48.000000,113.429800,39.162200 >}
	triangle { < -48.000000,109.947000,42.151280 >, <
-48.000000,112.065300,42.911290 >, < -48.000000,110.648800,40.272870 >}
-48.000000,111.336600,44.767790 >, < -48.000000,112.065300,42.911290 >}
-48.000000,111.955900,36.482100 >, < -48.000000,111.318600,38.382790 >}
	triangle { < -48.000000,114.668700,35.370880 >, <
-48.000000,111.955900,36.482100 >, < -48.000000,114.065000,37.271690 >}
	triangle { < -48.000000,109.213400,44.016940 >, <
-48.000000,111.336600,44.767790 >, < -48.000000,109.947000,42.151280 >}
-48.000000,110.577300,46.611920 >, < -48.000000,111.336600,44.767790 >}
-48.000000,112.560700,34.570810 >, < -48.000000,111.955900,36.482100 >}
	triangle { < -48.000000,115.240800,33.459780 >, <
-48.000000,112.560700,34.570810 >, < -48.000000,114.668700,35.370880 >}
	triangle { < -48.000000,108.448200,45.869880 >, <
-48.000000,110.577300,46.611920 >, < -48.000000,109.213400,44.016940 >}
-48.000000,109.787100,48.443680 >, < -48.000000,110.577300,46.611920 >}
udo:
IncludeFile 'C:\Geschaeft\Daten\\Geschaeft\Daten\deck.inc'
Name 'deck_group'
; Dimensions:
; Min_x: -100.000000	Max_x: -25.714280
; Min_y: -27.907740	Max_y: 160.714300
; Min_z: -139.182600	Max_z: 160.714300
[NONAME:Vertices]
14471
-48.000000 65.105780 100.803000
-48.000000 66.772050 99.707040
-48.000000 65.678620 97.731170
-48.000000 64.005300 98.835140
-48.000000 115.240800 -33.459780
-48.000000 114.668800 -35.370360
-48.000000 112.560900 -34.570290
-48.000000 113.133100 -32.649020
-48.000000 112.065300 42.911290
-48.000000 112.763100 41.042420
-48.000000 113.429800 39.162200
I just saw that moment, that the path of the include-file in the
udo-file looks mystrious. The path is: c:\geschaeft\daten and in daten
there are all the files (udo, inc, moray-file)
thanks a lot
Subject: Re: udo's
Date: 28 Nov 1999 12:10:12
Message: <384156e8.194579@194.174.214.110>
Try changing the line in the UDO to read:
 IncludeFile 'C:\Geschaeft\Daten\deck.inc'
- Lutz
