I know I'm overlooking something obvious here. How does one get Moray to
export .pov files? Under the render menu, I can hit export, but only can
export to .mdl files. Is there a plugin I need or some option I need to
enable? Using Moray v3.1 for Windows. It's not registered (yet ... only
had it for 3 days so far) is that a registered-only function?
__________________________________________________________________________
Paul Vanukoff van### [at] primenet com
http://www.primenet.com/~vanukoff/
disconnected from foreign server
Choose Render>Export from Moray's Menu. This will create a .pov and .inc
file in the directory you have selected in the Render Options dialog
("directory for POV files", moray\povscn\ by default).
> enable?
See above ^
No it is a standard feature.
Ken Tyler - 1100+ Povray, Graphics, 3D Rendering, and Raytracing Links:
Paul Vanukoff <van### [at] primenet com> writes:
: I know I'm overlooking something obvious here. How does one get Moray to
: export .pov files? Under the render menu, I can hit export, but only can
: export to .mdl files. Is there a plugin I need or some option I need to
: enable? Using Moray v3.1 for Windows. It's not registered (yet ... only
: had it for 3 days so far) is that a registered-only function?
Duh .. never mind .. found it (or rather, someone showed me where it is)
On 14 Oct 1999 08:50:24 -0400, Paul Vanukoff <van### [at] primenet com> wrote:
There's also a hotkey - I think it's CTRL+F9 to export a POV-Ray scene and
include file.
Alan - ako### [at] povray org - a k o n g <at> p o v r a y <dot> o r g
