I have just downloaded Liquid Spray plugin for Moray, and when I render the
scene (with lights and a camera, I wouldn't forget those:-), I see nothing.
The following fields are set:
Transformation: 1,1,1
Rotate: 0,0,0
Translate: 0,0,0
Strength: 11.0
Gravity: 9.5
Count: 200
Life: 1.8
Stretch: 3.0
Distance: 2.0
Evaporate: 0.0
Spray Loop: NOT SELECTED (I just want a still picture)
Nozzle spin: 33
Nozzle Angle: 80
Nozzle Width: 2
Neither Blob option is selected, although I have also tried various combo's,
to no avail
Use Ground Plane: NOT SELECTED
Turbulence Options:
Spray: .1
Scale: 0.0
Velocity: 0.0
Angle: 0.0
Spin: 0.0
Wind: 0.0
Spray Seed: 0.0
Flow Rate: 1.0
Time Scale: 1.0
Direction: 0,0,1
Wind Dir: 0,0,0
Use Material Texture: CHECKED
I have a material texture called RED, which is just a solid red pigment,
nothing fancy. When POV-Ray renders this, it says there are 0 frame-level
objects and 0 infinite objects. What am I doing wrong? Help? Thanks, and
please email me answers if you could.
John
alb### [at] rd simplexnet com
> Rotate: 0,0,0
> Translate: 0,0,0
> Strength: 11.0
> Gravity: 9.5
> Count: 200
> Life: 1.8
> Stretch: 3.0
> Distance: 2.0
> Evaporate: 0.0
> Nozzle spin: 33
> Nozzle Angle: 80
> Nozzle Width: 2
> to no avail
> Turbulence Options:
> Spray: .1
> Scale: 0.0
> Velocity: 0.0
> Angle: 0.0
> Spin: 0.0
> Wind: 0.0
> Spray Seed: 0.0
> Flow Rate: 1.0
> Time Scale: 1.0
> Direction: 0,0,1
> Wind Dir: 0,0,0
> John
Hi John!
I'm not shure, but I think you've got to set the "Spray Loop" to TRUE.
If you don't, the spray include file thinks that it has to generate an
animation with a spray object with increasing strength in time. Since
the clock value is zero the spray does not appear. Setting the "Spray
Loop" to TRUE will generate a spray oject with full strength over all
frames even if the clock value is zero.
