POV-Ray : Newsgroups : moray.win : RAW file problem- export to UDO with 3DWin 3.1... Server Time
10 Jun 2026 01:32:02 EDT (-0400)
  RAW file problem- export to UDO with 3DWin 3.1... (Message 1 to 3 of 3)
Subject: RAW file problem- export to UDO with 3DWin 3.1...
Date: 25 May 1999 19:33:50
Message: <374C76AE.F2335C14@mninter.net>
Hello. I am in need of help: I have a RAW file, exported from the beta
of a program. I tried to import it into 3Dwin(imports into Crossroads
ok...can view mesh and everything.), and then I try to export a UDO/INC
file .When I try to use the UDO/INC file in moray, it gives me the
error:
There was an error importing dragon.udo. The error was 'No [xx:
Vertices] section.' Ignoring this object.
I will post the RAW file, as well as the UDO/INC on
moray.binaries(excuse the format of the RAW file, my browser is screwed
up!)
Subject: Re: RAW file problem- export to UDO with 3DWin 3.1...
Date: 25 May 1999 21:10:59
Message: <374B3C0F.1F907375@its.bldrdoc.gov>
> error:
I just ran your RAW file through 3DWin (v3.4) and Moray accepted the
UDO/INC file without any complaints. It also read in the RAW file directly
and gave the same results for both.
Are you sure you're reading the UDO file into Moray, and not the INC file?
|               Tim Riley                 |
| Institute for Telecommunication Science |
|     National Telecommunications and     |
|       Information Administration        |
|          US Dept. of Commerce           |
|            Boulder, Colorado            |
|      E-mail:tri### [at] itsbldrdocgov      |
|     Per favore spenga le Sue scarpe     |
|  davanti abbandonare il nave spaziale.  |
Date: 25 May 1999 22:01:57
Message: <374B4850.54B9DBD9@home.com>
I think I've come across this problem before converting file formats. And I
too had to use crossroards. Try this and see if it works, this is how I did
it. Convert the RAW file in crossroads into a different format, other than
udo/inc like dxf. Then use 3Dwin to convert that file into udo/inc. Let me
know if this works, hope it helps.
> error:
> up!)
