POV-Ray : Newsgroups : moray.win : Height Field, or bump map?? Server Time
18 Nov 2025 20:14:55 EST (-0500)
  Height Field, or bump map?? (Message 1 to 5 of 5)
Subject: Height Field, or bump map??
Date: 20 May 1999 22:18:55
Message: <3744b47f.0@news.povray.org>
Hi, all.
Is there a way to wrap a height field around a non-planar surface (say the
face of a hemisphere?)
I know I can simulate this with bump-mapping, but the problem is that I ONLY
want the bumps.  If I create the sphere, bump-map it with the appropriate
texture, and then do a difference and cut out all of the sphere except for
the bumps, will the bumps still be visible??
(If it were flat, I'd use a height field and simply do a difference to
remove the height zero portion of the field.  Problem is that flat just
won't do what I want, and trying to generate the emblem I want using
primitive objects will take months, whereas it would be a matter of minutes
with the method I've described if it can be done.)
ZuluNiner{dbd}
ZuluNiner at fuckyou dot co dot uk
Subject: Re: Height Field, or bump map??
Date: 21 May 1999 00:06:05
Message: <37442515.9CA734F6@mninter.net>
I think you could do such a thing in polyray, but I don't know the specifics.
ZuluNiner wrote:
> Hi, all.
> ZuluNiner{dbd}
Given a lever long enough, one can move the world with little force
      MJ Engh
Date: 22 May 1999 10:44:01
Message: <3746B4BE.F7B0D873@istar.ca>
ZuluNiner wrote:
> Hi, all.
Not easily, and certainly not with Moray.
However... leveller (a HF editor) has a feature that lets you do this, and
exports to DXF, I think.. I don't know if Moray can handle this, but the file
converter might.
Date: 22 May 1999 11:59:05
Message: <37481796.2D1AC99D@mninter.net>
Just as a note- the files it generates are HUGE!!!!!(Within 1-2 megs, at
least...for a fairly small HF)
Simon de Vet wrote:
> ZuluNiner wrote:
> > Hi, all.
> converter might.
      MJ Engh
Date: 22 May 1999 19:54:04
Message: <37473550.F6F3D0D9@pacbell.net>
Simon de Vet wrote:
> ZuluNiner wrote:
> > Hi, all.
> converter might.
  As far as I know Leveller only supports cylindrical mapping
at this time and has no funtionality for spherical HF mapping.
  The only low cost/free program I know of that offers this is John
Beale's OrbCyl utility which is a stand alone utility designed to
convert a 3D topograpy into a cylindrical or spherical 3d shape
with the attributes of the original topography used. I am fairly
certain that it has support for Pov-Ray but I have not evaluated
the program so cannot say how effective it is.
  OrbCyl can be found at one or both of the links below.
http://www.best.com/~beale/
http://shell3.ba.best.com/~beale/gforge/
Ken Tyler
mailto://tylereng@pacbell.net
