POV-Ray : Newsgroups : moray.win : Randomization! Please! Server Time
10 Jun 2026 04:00:54 EDT (-0400)
  Randomization! Please! (Message 1 to 10 of 10)
Subject: Randomization! Please!
Date: 7 Apr 1999 22:00:11
Message: <370BFF9B.3B42A61@istar.ca>
I'd love to see a new feature for Moray, probably in the duplication
feild.
Let's say I want to make a row of icicles off the edge of a roof. I have
my icicle object, and I copy it 10 times, with a x translation of 5
units.
But this just looks silly. No icicles are this neat. It would be nice to
translate them all 5 units, +/- 2 units, to get clumps, and gaps. Also,
scaling them at 1x, +/- 0.5 ould provide a nice variation in lengths.
As is, this can be done manually, which is fine for 10 icicles. But if I
wanted to make 100 icicles, then things become ackward.
Perhaps a plugin, to emulat the duplicate feature could be used, but I
don;t know how hard it would be...
Simon
http://home.istar.ca/~sdevet
Subject: Re: Randomization! Please!
Date: 8 Apr 1999 06:48:00
Message: <370c7b50.0@news.povray.org>
Simon de Vet <sde### [at] istarca> wrote:
: As is, this can be done manually, which is fine for 10 icicles. But if I
: wanted to make 100 icicles, then things become ackward.
  Why? You can put 100000 objects exactly as easyly as 10 objects.
  See the help about #while.
Date: 8 Apr 1999 08:56:28
Message: <370C9914.4AFCB914@mninter.net>
I think what he is asking for(and I have already asked for), is a way to
introduce a random element to the scaling, translation and rotation of
duplicated objects.
Only I can prevent narcissism!
Date: 8 Apr 1999 13:44:59
Message: <370CDBD7.7E2045F9@pacbell.net>
Which is exactly what #while can do for you in a very small amount
 of code.
> duplicated objects.
Ken Tyler
mailto://tylereng@pacbell.net
Date: 8 Apr 1999 16:04:57
Message: <370CFDDC.3B10836D@istar.ca>
>  of code.
Which would kind of defeat the purpose of having a Modeller....
Date: 8 Apr 1999 18:44:03
Message: <370D21F1.1A9AB2E3@pacbell.net>
Simon de Vet wrote:
> >  of code.
  Not altogether true. The modeller is still needed to create the object.
It can also aid in the initial placement of the object in 3D space
before the beginning of the loop as well as establish the number of
iterations of the object that are needed for the length of the path it's
to be copied along. This would certainly save a lot of preprocessing
steps required if hand coding the same function into a pov scene.
  Lets face it, a simple rat knows when to jump ship rather that to
allow himself to go down with it. Humans with their superior
intelligence should be able to at least do as well as the rat in this
regard. Same is true with the modeller vs. hand coding functions issue.
You will be at once more knowledgable about how the process works than
your contemporaries who use a modeler alone and at the same time will
have a greater number of options available to you to work with by
choosing to learn how to work in both environments. Modelling programs
have a way of sheilding the user from fully understanding how a process
in pov works and as a result a number of options they could utilize
simply are not becuase of this lack of understanding.
  Perhaps a practical solution to the issue at hand would be a simple
plugin the pops up a standard while loop parameter settings window
inside Moray. When the parameters are set the generated code is
appended to the pov file so the results you are looking for are
realized. Maybe there is something I am missing but one of the wiz
kids out there with an extra 20 min. or so could likely have one
working during their one hour lunch break with time left to eat
and relax afterward.
Ken Tyler
Date: 8 Apr 1999 18:52:38
Message: <370D2527.B7BDD6D9@istar.ca>
Ken wrote:
> Simon de Vet wrote:
> > >  of code.
ok, ok... I give in...
I'll just learn the code, then.
As of now, I do use the code for some scene work. I often have used Moray to
place objects, then animated them in POV. Similarly to using the various
incs, like Galaxy, and the Lens Flare (still like Colefax's better than the
plugin)
I should just learn more. However, I don't want to start coding all my scenes
in straight code.. I tihnk that would lead to mroe frustration, and less
progress...
Date: 8 Apr 1999 21:58:29
Message: <370D505E.B0494580@mninter.net>
However, it is still easier to vizualize, and to model specific elements of a
scene within Moray...thus, randomization of translation, scaling, and rotation of
copied objects would be a bit more helpful in Moray. I'm sure that its very
helpful in POV-Ray, but due to the lack of conversion utilities for POV-Ray 3.1,
it would be much easier to do random objects before the export to POV-Ray.
Did that make any sense? Sorry, working off of about 5 hours of sleep.
>  of code.
> > duplicated objects.
> Ken Tyler
Date: 8 Apr 1999 22:07:15
Message: <370D527D.985CA86F@geocities.com>
YES YES YES!!  I'm trying to make a long hedge out of a single smaller
plant, but to make it look any good I need to have each copy rotated,
scaled, and moved slightly differently.  This is impossible (nearly) to
do with hundreds of copies.  This would be an excellent feature.  I
don't think it would really be that hard to add either.  Please someone
please!! :-)
		Kyle
> feild.
> units.
> Simon
Date: 9 Apr 1999 00:28:34
Message: <370d73e2.0@news.povray.org>
Anyhow it would be nice to have a noise check box in the duplication dialog
or ...
a scripting language like in Breeze
Philippe
