POV-Ray : Newsgroups : moray.win : Plugin idea Server Time
18 Nov 2025 23:33:59 EST (-0500)
  Plugin idea (Message 1 to 10 of 28)
Subject: Plugin idea
Date: 12 Mar 1999 19:47:25
Message: <36e9b59d.0@news.povray.org>
How about a "scripting language" plugin? It would make it really easy to add
new ideas...
For example, you could have a text file like so:
Dialog
  name "MyDialog"
  sidebar //puts it in the side menu; could be window instead to make it
popup
  //if it's window, have pos X,Y, Size X,Y
checkbox
 pos 10,10
 name "C1"
 value 0
label {
  pos 10,20
 value "This is C1"
editbox
 pos 10,30
 size 10
 name "RepeatVal"
 value "100"
output {
 print "#declare Max=" . $MyDialog(RepeatVal) . ";"
It's very rudimentary -- but I'm thinking of something along the lines of
the scripting language found uin the mIRC chat program for windows.
(http://www.mirc.co.uk )
Anyone game for this?
Twyst
Version: 3.1
GCS/O d+(-) s-: a-- C+++(++++) UL++ P+(--) L+ E- W+++>$ N++ o- K-
w+(---) O- M-- V- PS+ PE+ Y PGP t 5 X R tv- b++++ DI++ D G++ e h* r-- !y++
Subject: Re: Plugin idea
Date: 12 Mar 1999 20:05:08
Message: <36e9b9c4.0@news.povray.org>
Oh ya, thinking about this a bit more:
All the math can be done by pov-ray itself -- so you don't need any
calcualtion functions (Unless you want to do a wireframe representation --
this could be done as well, I think.. . add drawing commands, maybe -- the
plugin defines the points in an array, or a loop, or something..  and passes
the list to the drawing method  )
also, the only thing necessary for povray output, is a method of getting the
values from the dialog, and a print command (that gets called when the
plugin is polled for output)-- after all; povray is happy with text.
Hmm...
Wireframe output prob. isn't possible.. but that's not a big deal, imho.
I can see this bringing out a whole bunch of math or repetitive "scripts"...
Version: 3.1
Twyst wrote in message <36e9b59d.0@news.povray.org>...
add
>new ideas...
>Dialog
>  name "MyDialog"
>popup
>checkbox
> pos 10,10
> name "C1"
> value 0
>label {
>  pos 10,20
> value "This is C1"
>editbox
> pos 10,30
> size 10
> name "RepeatVal"
> value "100"
>output {
>Twyst
>-----BEGIN GEEK CODE BLOCK-----
>Version: 3.1
>------END GEEK CODE BLOCK------
Date: 13 Mar 1999 02:31:32
Message: <36ea1454.0@news.povray.org>
Why not Java ?
add
>new ideas...
>Dialog
>  name "MyDialog"
>popup
>checkbox
> pos 10,10
> name "C1"
> value 0
>label {
>  pos 10,20
> value "This is C1"
>editbox
> pos 10,30
> size 10
> name "RepeatVal"
> value "100"
>output {
>Twyst
>Version: 3.1
Date: 13 Mar 1999 04:59:53
Message: <36ea3719.0@news.povray.org>
>Why not Java ?
Huh?
Johannes.
Date: 13 Mar 1999 05:58:43
Message: <36ea44e3.0@news.povray.org>
>>Why not Java ?
>Huh?
>Johannes.
Uhu !
Philippe
Date: 14 Mar 1999 22:48:42
Message: <36ec831a.0@news.povray.org>
Uhm.
Java sucks. End of story. Apart from the fact that Moray doesn't use or
support it.
Version: 3.1
Ph Gibone wrote in message <36ea1454.0@news.povray.org>...
>Why not Java ?
Date: 15 Mar 1999 02:54:49
Message: <36ecbcc9.0@news.povray.org>
>Uhm.
>support it.
Java Exists. End of story
Moray doesn't use or support any scripting language so far
Philippe
Date: 15 Mar 1999 03:33:42
Message: <36ecc5e6.0@news.povray.org>
Ph Gibone wrote in message <36ecbcc9.0@news.povray.org>...
>>Uhm.
>>support it.
That's the reason for my previous "Huh?": Java is not a scripting language,
so I don't really see a good reason to use it here.
Maybe you mean JavaScript??? (Wouldn't be very useful either, since it is
mostly web-oriented)
Johannes.
Date: 15 Mar 1999 07:57:09
Message: <36ED041C.CDB298F9@pacbell.net>
> Philippe
  Moray can use the older versions or Pov script if run thorugh a parser
first. Has been able to do that for years now. Not that many people
go thorugh the trouble but it is possible.
Ken Tyler
mailto://tylereng@pacbell.net
Date: 15 Mar 1999 12:54:41
Message: <36ed4961.0@news.povray.org>
You're right on this point, but at least you can define something which more
or less looks like a dialog box !
BTW I'm not a Java freak neither a Java fan but when something exists you
can take the good out of it !
Philippe
