POV-Ray : Newsgroups : moray.win : Feature/plugin Request .... Server Time
19 Nov 2025 01:19:40 EST (-0500)
  Feature/plugin Request .... (Message 1 to 9 of 9)
Subject: Feature/plugin Request ....
Date: 10 Feb 1999 12:22:00
Message: <36c1c038.0@news.povray.org>
How about cylinders/cubes/cones that you can define the endpoints of,
instead of having to rotate & scale them?
I can see a plugin that has just these normal primitives, but with a numeric
entry :
Cube - enter x1,y1,z1 and x2,y2,z2
Cylinder - enter x1,y1,z1 ,  x2,y2,z2  , radius
Cone - enter x1,y1,z1 ,  x2,y2,z2  , radius1, radius2
It would make life MUCH simpler, as well as make cleaner code than taking a
unit cylinder and scaling/rotating/translating.
Twyst
povray.doc -- An engaging tale about a spanish guy named Manual.
Subject: Re: Feature/plugin Request ....
Date: 10 Feb 1999 12:40:06
Message: <36C1C438.71E40BA0@pacbell.net>
> entry :
> Twyst
Are you trying to be funny or am I missing something here ?
A quick example of defining end points on a cylinder would be:
for x
cylinder{x*-1,x*1,1>}
for y
cylinder{y*-1,y*1,1>}
for z
cylinder{z*-1,z*1,1>}
for cones you can do the same thing
for x
cone{x*-1, 1, x*1, 0>}
for y
cone{y*-1, 1, y*1, 0>}
for z
cone{z*-1, 1, z*1, 0>}
and for cubes it takes a little more work but you can
do about the same as above
box{-.5,.5}
 a unit cube
box{0,1}
a unit cube that extends from lower left corner at
xyz = 0 to xyz +1
If you use all six direction vectors in the cylinder and
cone primitives you can scale and rotate them any direction
you like without have to further rotate and scale them with
extra statements.
Have I missed something ?
Ken Tyler
mailto://tylereng@pacbell.net
Date: 10 Feb 1999 13:16:11
Message: <36C1CD4F.16B3D1F@istar.ca>
> > entry :
> > Twyst
<snip>
I think his point is for odd angles, and the such.
If I want to connect the points 0,0,1 and 0,1,0 with a cyllinder or cone, it would
lie on an angle. BUT, it would also have to have a length of [root 2].
For other points to be connected, other lengths are needed.. and since Moray is a
visual modeller, it would be nice to be able to do this without using a
calculator.
I've wanted this myself...
Plus, for a cylinder , cone, or cube, the scaling is applied after the texture,
resulting in an often distorted texture, unless you put the object into a group,
and apply the texture to the group. For multiple items this is fine, but if you
want to apply a texture to just one object, it's a bit irritating.
Simon
http://home.istar.ca/~sdevet
Date: 10 Feb 1999 13:38:15
Message: <36C1D1DA.379FC52E@pacbell.net>
> > > entry :
> > > Twyst
> <snip>
> calculator.
> Simon
Actually I did reply in haste. I thought this was the povray.windows
group. I understand the difficulties inherent in such a feature when
talking about modeling programs. I couln't believe Twyst didn't know
how easy it was to define end points in pov. My mistake and apologize
for the quick fire response. It does build good a argument for hand
coding though :)
Ken Tyler
Date: 10 Feb 1999 13:44:07
Message: <36c1d377.0@news.povray.org>
Ken wrote in message <36C1C438.71E40BA0@pacbell.net>...
numeric
>> entry :
a
>> Twyst
Yup. This is for MORAY. there is NO current way to define where your
endpoints are WITHOUT having to do a LOT of scaling/rotating.
Notice how you have to build a cylinder currently.
you click cylinder.
It places a 1x1x1 cylinder at the origin
you scale it to the right dimensions
You rotate and translate it until you get it right.
(Case in point: YOU do a cylinder with points <2.3,1.2,3> <.15,8.2,2.5>
without spending 5 minutes doing s/r/t to make it fit.)
Repeat for each cylinder in a scene.
Output code:
cylinder { // Cylndr001
  <0,0,1>, <0,0,0>, 1
  material {
    PDB_Tex_C
  scale <0.7, 1.0, 6.9>
  rotate 35.0*y
  translate  <3.6, 0.0, 1.3>
Now, the plugin:
You click Cylinder[2 point]
It puts a 1x1x1 cylinder at the origin.
You enter the first point. <2.3,1.2,3>
It places endpoint 1 there.
You enter the second point. <.15,8.2,2.5>
It places endpoint 2 there.
You enter the radius.
It changes the radius.
Done. MUCH faster to do.
Output code:
  <2.3,1.2,3> , <.15,8.2,2.5> , 1
  material {
    PDB_Tex_C
MUCH cleaner.
>Ken Tyler
Twyst
Date: 10 Feb 1999 13:52:23
Message: <36c1d567.0@news.povray.org>
>coding though :)
>Ken Tyler
Actually, I do both. I do my major scene layout in Moray, and tweak it in my
SuperPatch enabled Pov-Ray.
I also code quick custom programs to generate objects for Moray -- my latest
trick is to hack LParser and a) fix the DXF output, and b) change the BLB
format to CTD format (which I convert using another program.) (massive
kludge, doesn't work all that well. =( I need to sit down and write a
LParser for Moray.. .  Eventually. AFTER I get everything else done.)
Twyst
Date: 10 Feb 1999 14:16:21
Message: <36c1db05.0@news.povray.org>
Twyst schrieb in Nachricht <36c1c038.0@news.povray.org>...
numeric
>entry :
YES! It would really make life simpler. Especially, if you want to use the
cylinders to define blobs. If you enlarge a unit cylinder (esp. if you
elongate it), the rounded edges of the blob cylinder will we elongated too.
This is not the desired effect.
But they would have to be real cylinders, not converted to
translated/rotated/scaled cylinders after all (but I don't know if a plugin
can do this).
I've had a look at the C++ code for Moray plugins, but I'm lost with the
VC/MFC objects. If I'd only have the definition of the MFC class CObject,
I'd be able to translate the MFC C++ headers to Delphi32 (yes, this is
possible) and create any kind of plugin desired.
Rudy Velthuis
Date: 11 Feb 1999 05:07:58
Message: <36c26b82.6443069@news.stmuc.com>
You don't need to use MFC stuff to make a plugin. The Plugin SDK has a
pure C Win32 API version that uses no MFC stuff.
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
Date: 11 Feb 1999 07:21:30
Message: <36c2cb4a.0@news.povray.org>
Lutz Kretzschmar schrieb in Nachricht <36c### [at] newsstmuccom>...
I know. This is the easy part (for the converter).
But I think it is also possible to convert the MFC classes used (CInterface
etc.) to Object Pascal. I've already converted COM-interfaces to Pascal,
when Object Pascal didn't support interfaces directly and converting CObject
should be possible too. MS C++ classes and Object Pascal classes have the
same binary structure nowadays (Borland takes great care of compatibility,
because of Delphi and C++Builder). But I need to know the definition
(methods, etc.) of the base class, to make it as compatible as needed.
Using classes would greatly ease the creation of Delphi components, I think.
Creating a plugin like requested in this thread would propably be a matter
of hours, not days. Using the normal API would be like programming Windows
using the generic API (yuk) instead of components and classes.
BTW, why don't you implement real COM interfaces (as a new layer, not
replacing the existing one)? Couldn't be too hard to achieve, and would make
Moray open to any kind of language that can handle COM (i.e. implement COM
interfaces).
Rudy Velthuis
