POV-Ray : Newsgroups : moray.win : lens flare plugin Server Time
10 Jun 2026 07:49:23 EDT (-0400)
  lens flare plugin (Message 1 to 2 of 2)
Subject: lens flare plugin
Date: 17 Jan 1999 02:27:32
Message: <36a18f60.983046@news.povray.org>
It is my understanding (correct me if I'm wrong) that although
Moray3.1 ships with a plugin for Nathan Kopps' LensFlare include file,
the plugin just provides for exporting parameters used by the lens
flare include which is actually processed by POVRay. If this is true
where can I get Nathan's include file? Also how do I set up POV to use
the include file automatically when rendering from Moray?
Thanks for your help.
Stefan (USA)
Subject: Re: lens flare plugin
Date: 17 Jan 1999 07:35:35
Message: <36a1d36a.8470519@194.174.214.110>
Hi stefan, you recently wrote in moray.win:
OK, you are wrong<g>. The plugin exports the lens flare parameters and
then include 'NKFlare\xxxx.inc'. If you don't change the directories
from the default installation it'll work out of the box. If you do,
you'll need to copy the NKFlare subdirectory (found in POVSCN) to the
directory where you have your POV files created.
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
