POV-Ray : Newsgroups : moray.win : Liquid Spray Plugin Server Time
10 Jun 2026 07:50:14 EDT (-0400)
  Liquid Spray Plugin (Message 1 to 10 of 11)
Subject: Liquid Spray Plugin
Date: 16 Jan 1999 21:50:47
Message: <36a14ed0.4009804@news.povray.org>
I tried to install the new liquid spray plugin. I put the SprayMFC.dll
in my moray plugins directory. However, checking the loaded plugins
screen does not show it loaded (only the plugins that come with the
Moray distribution show up).
It also does not show up on the create|plugins pull down.
What do I do with the spray.inc file?
Perhaps I'm doing something wrong (it's the first time I tried to
install a plugin.
Stefan (USA)
Subject: Re: Liquid Spray Plugin
Date: 17 Jan 1999 10:40:09
Message: <36a20459.0@news.povray.org>
stefan wrote in message <36a14ed0.4009804@news.povray.org>...
Hmm ! don't know why this should be expect that you may be pointing to
another directory if you have two versions of Moray installed?
You need to put it in the POVRAY include directory with the other srayg.inc
file it would probably be a good idea to download Chris' zip file but
overwrite the spray.inc file with the one supplied by me (Chris' zip also
has the spray.htm file in it)
>install a plugin.
No everything seems OK!
Keith
Date: 17 Jan 1999 10:43:10
Message: <36a2050e.0@news.povray.org>
>install a plugin.
>Stefan (USA)
It's not just you, I'm having the same problem :(
Somebody out there must know the answer!
Equiprawn
Date: 17 Jan 1999 10:51:30
Message: <36a20702.0@news.povray.org>
Incase you don't know it here is Chris' WWW addr
http://www.geocities.com/SiliconValley/Lakes/1434
Keith
>install a plugin.
>Stefan (USA)
Date: 17 Jan 1999 15:41:55
Message: <36a24b13.0@news.povray.org>
I can't get it to work either.
Andy
Keith Hull wrote in message <36a20702.0@news.povray.org>...
>Keith
>>install a plugin.
>>Stefan (USA)
Date: 17 Jan 1999 17:19:36
Message: <36A2624F.69AC950@istar.ca>
> >install a plugin.
> >Stefan (USA)
Me too...
Date: 17 Jan 1999 18:02:12
Message: <36A26C8F.ED98FF1F@geocities.com>
I think he the plugin released requires MFC shared dll's.  I wrote a
shader for trueSpace and had the same problem, people who didn't have
the correct dll's couldn't load it.  I don't know what dll's you need
because I just started staticly linking every plugin/shader I make.
			-fjr
Simon de Vet wrote:
> > >install a plugin.
> > >Stefan (USA)
> Me too...
Date: 18 Jan 1999 13:14:18
Message: <36a379fa.0@news.povray.org>
Andrew Cocker wrote in message <36a24b13.0@news.povray.org>...
Lutz has suggested to me that it may be that I've sent him a copy of the
plugin that is compiled for debug mode and so needs different dll's .....
I'll recompile for release and post it to Lutz - it may help those of you
that can't get it to load.
Best Regards,
Keith
Date: 19 Jan 1999 23:01:13
Message: <36a55509.0@news.povray.org>
Hi all,
I am having real problems with the spray plugin, I have dl'd the origion
POVray plugin, and put the inc files in my POVray include dir, dl the spray
plug, put the dll in the Moray Plugins dir, and overwritten the spray.inc
file in the POVray inc dir with the one provided.
no matter what i do it allways page faults, and sometimes times my whole PC
down with it.
I am running win98, directx6, all of the widows updates from ms installed,
MS VC 6 with MSVS SP 1 installed.
MORAYWIN caused an invalid page fault in
module MFC42D.DLL at 0177:02e77216.
Registers:
EAX=00000000 CS=0177 EIP=02e77216 EFLGS=00010246
EBX=815de5b0 SS=017f ESP=0099f474 EBP=0099f484
ECX=00000000 DS=017f ESI=014f0000 FS=3a4f
EDX=00000003 ES=017f EDI=00000000 GS=4f96
Bytes at CS:EIP:
83 38 00 75 11 6a 7a 68 14 bf ea 02 e8 69 fa ff
Stack dump:
00000000 014f0000 815de5b0 00000000 0099f4a4 02e2bb34 00000000 014f0000
815de5b0 00000000 bffbfe14 bff79230 0099f4c4 02e61a9d 00000003 00000000
Date: 20 Jan 1999 16:32:13
Message: <36a64b5d.0@news.povray.org>
Rick wrote in message <36a55509.0@news.povray.org>...
>Hi all,
>down with it.
Hi Rick,
I run almost the exact same system, except I use MSVC 5, however I've sent
Lutz a new version that is not compiled for debug, this may cure your
problem. However you are the first person that's said it crashes, and
somehow I don't think a release compile will cure your problem (but you
never know :-).
Best Regards,
Keith
