POV-Ray : Newsgroups : moray.win : setting rotation center of objects ? Server Time
19 Nov 2025 02:46:23 EST (-0500)
  setting rotation center of objects ? (Message 1 to 2 of 2)
Subject: setting rotation center of objects ?
Date: 10 Jan 1999 14:16:12
Message: <3698fa74.4315190@news.stmuc.com>
Hi!
Does anyone know how to set the center of rotation of an object ?
I know, there's the rather complicated way to create the object and
then translate it - but...is there an other possibility ?
Thanks
Tom
Tom Kaeser
Remove the x!
tka### [at] g26ethzch
tom### [at] hotmailcom
Subject: Re: setting rotation center of objects ?
Date: 10 Jan 1999 14:33:55
Message: <369901b2.12289551@194.174.214.110>
Hi Tom Kaeser, you recently wrote in moray.win:
If you're using V3.1 then select the object and press 'A' or click on
the 'Local Coordinates' button under the transformations. Then use the
mouse to drag the XYZ axis to the place where the center of rotation
should be.
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
