Dear Moray Users,
This is just an announcement and reminder for you to keep an eye on
the F.A.Q. and Bugs page on our website for the latest list of bugs
and questions concerning Moray.
http://www.stmuc.com/moray/mefaq.html
It will be updated whenever new bugs appear or the same question keeps
popping up.
The current list of known bugs is listed below and will be fixed in
the next maintenance release, but be sure to visit the website
regularly.
Bugs in Build 4215
- Renaming a media that is being used as the global media in
the scene does not cause the name change to be propagated to
the global media. POV-Ray reports an error.
Workaround is to go to the Media Tab in the Scene|Settings
dialog and to reset the media.
- The logic of the Uniform flag of the Noise Modifiers is
inverted.
- Bounding boxes of objects whose pivot point has been
transformed is incorrectly calculated.
- poly and cubic wavetypes are not supported in normal
noise modifiers.
- transformations are not supported for materials.
- There is a problem with the wireframe display when
reference objects reference other reference objects in
a group. Renders are not affected.
- Merging a MDL file that has an object selected that will
be renamed due to merging, causes a fatal assertion.
Workaround is to not have an object selected when
saving the MDL.
- There is a bug that causes a 'File not open' error when
reading a file that crops up seldomly (it's been around
since V2.5).
There is no workaround. If you get this error with
an important file, contact us.
- Lutz
email : lut### [at] stmuc com
Web : http://www.stmuc.com/moray
