POV-Ray : Newsgroups : moray.win : Grid Pattern? Server Time
10 Jun 2026 08:57:23 EDT (-0400)
  Grid Pattern? (Message 1 to 7 of 7)
Subject: Grid Pattern?
Date: 2 Jan 1999 17:19:44
Message: <368E9B5C.F97A05D3@ix.netcom.com>
Is there an easy way to create a Grid Texture? Brick
looks nice but inappropriate for square tiles (defining
tile size and gap)...
TIA...
	R
Subject: Re: Grid Pattern?
Date: 2 Jan 1999 17:35:05
Message: <368E9E15.BF648313@mninter.net>
I would suggest a gradient. Make it a very limited strand of color in a
colormap, and then make the color map gradient run in a couple of
directions.
> TIA...
>         R
Gods don't save people. People save people.
Date: 2 Jan 1999 23:57:55
Message: <368EF920.3B0B7BE7@istar.ca>
> directions.
I did this in my blackhole pic.. looks quite
good!http://home.istar.ca/~sdevet/hole.jpg
> > TIA...
> >         R
Date: 3 Jan 1999 11:46:05
Message: <368F9DD0.7677BED0@mninter.net>
Great picture- really looks like those cool CGs from that PBS series "Stephen
Hawkin's Universe". Though I didn't know whether the blackhole made gravity
beyond its event horizon. But, hey, that defys logic, but blackholes do
anyway.
> > directions.
> > > TIA...
> > >         R
Date: 3 Jan 1999 18:12:17
Message: <368FF927.DB66CB9D@ix.netcom.com>
I got the gradient running in one direction, how do you
"layer" it so it runs in different directions? When I
select x & y I get a concentric square pattern instead
of a grid...
Thanks...
	R
> directions.
> > TIA...
> >         R
Date: 3 Jan 1999 20:05:17
Message: <36901354.FF83FA16@pacbell.net>
> of a grid...
> Thanks...
>         R
You will need to layer the pigments. The scond layer will need
some transperancy to let the second layer through. Either that
or use the brick pattern in a single layer but not in the conventional
way. Try rotating it so it is seen on end. This gives a nice grid pattern
that is uniform.
Ken Tyler
tyl### [at] pacbellnet
Date: 4 Jan 1999 07:57:23
Message: <3690B9B8.972CF40E@mninter.net>
Create a layered texture, with the same gradient pattern in each layer, but
with each one having a different direction. Does that help?
> of a grid...
> Thanks...
>         R
> > directions.
> > > TIA...
> > >         R
