Hello,
Does anybody know of a method of making curved cylinders? It'd be very
useful in furniture as well as other things -- thanks.
Joe
Well, there are a few different ways- 1. Bezier Patches> Pros: Inhouse.
Just click, and edit. Cons: Take FOREVER to parse(I had a seen, exported
from sPatch, took 20 minutes to parse!)2. STOMP 3D- Extrude along spline
path function is awsome. Great for piping, etc. Pros: Great objects!
Supports NURBS. Cons:Java Based, so you have to download that. And you have
to export and convert it a couple times. 3. INC files: Don't know of the
URLs for any. Pros: Work in POV- Ray. Cons: Works in POV-Ray(and only
pov-ray) No MOray support.
The Prevers wrote:
> Hello,
> Joe
Gods don't save people. People save people.
Thanks, that's what I'm looking for =)
Joe
The Prevers wrote:
> Hello,
Well, to state the blindingly obvious ( >:-) ), torii are the way to go,
for most things. Now, you'll never get torii in the shapes you want, but
90% of the time, some scaling, some clipping, and some fiddling will get
you what you're looking for. And, as opposed to nurms, and patches, and so
forth, it's very fast, and very easy....
Simon
http://home.istar.ca/~sdevet
Thanks much. I'm afraid it'll take a lot of stating the blindingly obvious
before I get good at this! ;-)
Joe
>> It'd be very useful in furniture as well as other things -- thanks.
You can use Ron Parker's Superpatch unofficial build of POV-Ray, which
incorporates Jochen Lippert's Sphere Sweeps patch. You can 'cap' the ends of
the sweeps with cylinders to make the sweep appear as a continuously curved
cylinder. Very useful for furniture.
- Alan
"The Wolfman been everywhere and he seen everything....and here I
sit, sucking popsicles..." - radio station manager played by the
late Wolfman Jack, in George Lucas' "American Graffiti" (1973)
> - Alan
But then again that patch is not supported in Moray so ...
Ken Tyler
tyl### [at] pacbell net
Ken wrote in message <368F5CC7.209AC4C2@pacbell.net>...
of
curved
>> - Alan
HOWEVER.. There IS a way to make it easy. Set a number of spheres, with the
radius you want, at the points you want. Name them all something that is
easy to search for, like "SphereSweepUnit". Then, in the pov-ray 3.1 editor
(win95) do a search for each instance, and copy them into a sphere_sweep
statement. It'll give you the points you want... at a minimum of tweaking...
twyst
Even easier, just create a "SuperQ" object in Moray, and click the
"cylinder" preset option in its "Superquadric parameters" box. Scale as you
please:)
Matt
The Prevers wrote in message <368E8606.A90114B7@turbont.net>...
>Hello,
>Joe
Hmm, no, I think he was looking for "curved" cylinders, not "rounded" ones
(which also could be created via the new plug-in element Rounded Disc or
what it is called, but then, that doesn't seem to be what he is looking
for...)
Johannes.
Matthew Bennett wrote in message <368f93da.0@news.povray.org>...
you
>please:)
>Matt
>>Hello,
>>Joe
