POV-Ray : Newsgroups : moray.win : Moray 3.1 Problems Server Time
10 Jun 2026 08:59:12 EDT (-0400)
  Moray 3.1 Problems (Message 1 to 5 of 5)
Subject: Moray 3.1 Problems
Date: 25 Dec 1998 10:41:17
Message: <3683B1DD.98E8EDF4@linknet.net>
I'm having problems in Moray 3.1 when trying to preview a texture
and when trying to render an image. This is the error message I get
when trying to preview a texture. Any help would be appreciated.
#declare PreviewTexture =
   material  <----ERROR
POVTXTR.POV:12: error: object or directive expected but undeclared
identifier 'material' found instead.
Returned from renderer (non-zero return value)
Calvin: Life is like topography, Hobbes.
There are summits of happiness and success.
Flat stretches of boring routine.
And valleys of frustration and failure.
http://www.fortunecity.com/underworld/riven/473/
http://www.rhema.net/chef/
Subject: Re: Moray 3.1 Problems
Date: 25 Dec 1998 13:23:40
Message: <3683D7DE.488E5E8A@worldnet.att.net>
>    material  <----ERROR
Is this a new material that you created? It sounds like you have left
something out, I had similar problem in Moray 3.0 when I was trying to
create a image map. I finally figured out what I was missing and now I
have a really good grass texture. Post the entire material if you are
not able to find the problem.
Daniel Hargreaves
SD Graphics
ArchSymb for AutoCAD and IntelliCAD
http://home.att.net/~dkh007/archsymb
CADD Standards
http://home.att.net/~dkh007/caddstd
Date: 25 Dec 1998 17:06:25
Message: <36840C93.49425473@flash.net>
>    material  <----ERROR
This is a POV problem and not a Moray problem.  It isn't with
the material statement but with what preceeds it.  I think you are
likely missing a "}" or something similar -- if you haven't
figured it out, post a slightly fuller code fragment here.
Dan
Date: 25 Dec 1998 18:20:02
Message: <36841da2.0@news.povray.org>
Matthew Henderson heeft geschreven in bericht
<3683B1DD.98E8EDF4@linknet.net>...
>   material  <----ERROR
It looks to me that POVRay doesn't recognize the word material itself.
Are you sure you're using POV-Ray 3.1? Cause the material statement doesn't
exist in an older version of POV.
ZK
Date: 26 Dec 1998 14:08:51
Message: <36848BCA.634B47F6@tx.technion.ac.il>
This error is due to the fact that you are probably using POV-Ray 3.0
instead of 3.1.
>    material  <----ERROR
