POV-Ray : Newsgroups : moray.win : Making holes in walls... Server Time
10 Jun 2026 14:42:52 EDT (-0400)
  Making holes in walls... (Message 1 to 6 of 6)
Subject: Making holes in walls...
Date: 1 Mar 1998 23:32:58
Message: <34FA367A.951BFF92@pacbell.net>
Hello again,
I was wondering how it might be possible to cut a hole for a door in a
pre-existing wall without re-modelling the whole wall as four separate
pieces in Moray for Windows. I tried creating a hollow box and inserting
it into the wall, but it didn't seem to change anything. I have also
tried assigning the box a glass texture, but that didn't do it either...
Suggestions?
Thanks,
Bryan
Subject: Re: Making holes in walls...
Date: 2 Mar 1970 00:04:20
Message: <01bd4598$8980b120$74fa5ecf@mayadiva>
If you already have your wall, then create a cube and shape it to the size
of your door or hole and position it where you want it. Then create a CSG
object and add both the wall and the door to that. Then choose difference
for the operation. You can click on evaluate to see the effect, and cycle
order if it's backwards (the wall is being subtracted from the door).
It also helps to take the time to read the documentation <g>.
Frank Salinas
Bryan R. Carroll <NoS### [at] pacbellnet> wrote in article
<34FA367A.951BFF92@pacbell.net>...
> Hello again,
> Suggestions?
> Thanks,
> Bryan
Date: 2 Mar 1998 00:38:20
Message: <34FA45CC.8C95F274@pacbell.net>
<<It also helps to take the time to read the documentation <g>.>>
I Did; must not have stuck to the inside of my Brain Housing Group.....
Thanks!!
Bryan
Date: 2 Mar 1970 20:06:16
Message: <34fb5788.0@news.povray.org>
Frank Salinas (fra### [at] ixnetcomcom) wrote:
: If you already have your wall, then create a cube and shape it to the size
: of your door or hole and position it where you want it. Then create a CSG
: object and add both the wall and the door to that. Then choose difference
: for the operation. You can click on evaluate to see the effect, and cycle
: order if it's backwards (the wall is being subtracted from the door).
: It also helps to take the time to read the documentation <g>.
Ho! Where is that exactley in docs? I've been translating the manuals to
Croatian, and didn't found any examples of it...
And, the question I keep asking.... How can I change the axis of rotation of
an object...
	Mike
Ovo je moj signacur fajl...
Date: 3 Mar 1970 02:32:18
Message: <kkqufgcbspqwenismafk.pminews@news.povray.org>
Hello!
I suppose he was speaking about the _PoV_ documentation. There you can find
anything about CSGs - I hope noone expects the Moray DOCs to include the
entire PoV DOC stuff.
>an object...
Put it into a group (maybe with including a little dummy object - f.e. placed
inside the real one - to avoid PoV warnings) rotate and translate it until
the wished rotation axis of the object lies on the z-axis of the group -
done!
Now you can rotate the group which is equivalent to rotating the basic object
around the desired axis of rotation. You may 'ungroup in place' it later, if
you don't need to modify it again.
Bye,
   Ingo.
Date: 3 Mar 1970 17:54:14
Message: <34fc8a16.0@news.povray.org>
Ingo Guenther (ing### [at] REMOVEnetcolognede) wrote:
: Hello!
: >: It also helps to take the time to read the documentation <g>.
: >Ho! Where is that exactley in docs? I've been translating the manuals to
: >Croatian, and didn't found any examples of it...
: I suppose he was speaking about the _PoV_ documentation. There you can find
: anything about CSGs - I hope noone expects the Moray DOCs to include the
: entire PoV DOC stuff.
Well, i suppose you're right... Although that should be covered in the
Tutorial section of moray...
: >And, the question I keep asking.... How can I change the axis of rotation of
: >an object...
: Put it into a group (maybe with including a little dummy object - f.e. placed
: inside the real one - to avoid PoV warnings) rotate and translate it until
: the wished rotation axis of the object lies on the z-axis of the group -
: done!
: Now you can rotate the group which is equivalent to rotating the basic object
: around the desired axis of rotation. You may 'ungroup in place' it later, if
: you don't need to modify it again.
That's what I've been looking for. That should definitley go into the Moray
manuals!
	Mike
