POV-Ray : Newsgroups : moray.win : LOOK OUT! Moray bug makes file unreadable! Server Time
19 Nov 2025 04:02:13 EST (-0500)
  LOOK OUT! Moray bug makes file unreadable! (Message 1 to 2 of 2)
Subject: LOOK OUT! Moray bug makes file unreadable!
Date: 28 Dec 1998 14:46:20
Message: <01be329a$7622d820$1ddc7dc2@goyra>
I downloaded Build 4180,
opened an old scene, and modified
it a few times. Then I saved the
object within it using "Save Object As."
	When I tried to reload the
resulting MDL file the program
said it could not load because
a "newer version of Moray" had
made the file.
	I downloaded the patch,
(build 4196) and tried to load that
same object file. THIS time it says
there is an "error in MDL file"
	If it were not for the backup
file I would have lost my work. (The
backup file is readable because it
was created with "save scene" and
not "save object")
				David
Subject: Re: LOOK OUT! Moray bug makes file unreadable!
Date: 29 Dec 1998 02:54:39
Message: <36888b88.4536022@194.174.214.110>
Hi David Byrden, you recently wrote in moray.win:
> made the file.
Could you send me the MDL file? That is not normal behaviour. The two
builds share the same file format.
Note that Moray also makes a .BAK file everytime it saves a file.
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
