POV-Ray : Newsgroups : moray.binaries : Binary - What am I doing wrong here? Server Time
24 Jun 2026 03:53:19 EDT (-0400)
  Binary - What am I doing wrong here? (Message 1 to 8 of 8)
Subject: Binary - What am I doing wrong here?
Date: 15 Apr 2001 07:04:16
Message: <3ad98030@news.povray.org>
I did this, kinda simplistic, but it seems it doesen't want to accept my
bump map, the rendered image's ground doesen't look anywhere near 3d
Download 'thingie.zip' (394 KB)
Subject: Re: Binary - What am I doing wrong here? Altered file attached. - soil.mdl [1/1]
Date: 15 Apr 2001 08:20:37
Message: <MPG.1543a2413da296df9898c6@news.povray.org>
On Sun, 15 Apr 2001 07:04:29 -0400, Olivier Gagnon wrote...
I suspect that it is because you're using a plane.  In this situation I
tend to use a heightfield.
Have a look at the attached .mdl and see if that's more like you were
after.
Admittedly the main problem with using the Heightfield method is that you
can be limited in the size of terrain you can create unless you have
stupid amounts of memory.
If the attached file is not what you're after, feel free to ask again,
but could you try to post a little more information on exactly what
you're after next time?
Bye for now,
     Jamie.
Download 'soil.mdl.dat' (6 KB)
Date: 15 Apr 2001 11:15:27
Message: <3ad9bb0f$1@news.povray.org>
Yes this is what I'm after
But the ground isin't tiled, that's what I was looking for!
"Jamie Davison" <jam### [at] ntlworldcom> wrote in message
news:MPG.1543a2413da296df9898c6@news.povray.org...
> after.
> Bye for now,
>      Jamie.
Subject: Re: Binary - What am I doing wrong here? (Try this one then) - Tiled soil.mdl [1/1]
Date: 16 Apr 2001 06:19:29
Message: <MPG.1544d75297e153129898cb@news.povray.org>
On Sun, 15 Apr 2001 11:15:58 -0400, Olivier Gagnon wrote...
OK then, try this one that I whipeed up in about five minutes.  IS this
more what you were after?
Bye for now,
     Jamie.
Download 'Tiled soil.mdl.dat' (11 KB)
Date: 16 Apr 2001 17:11:38
Message: <3adb600a@news.povray.org>
Wow! Exactly!!!
How did you do those 'shortcuts' thingies?
news:MPG.1544d75297e153129898cb@news.povray.org...
> Bye for now,
>      Jamie.
Date: 16 Apr 2001 17:12:38
Message: <3adb6046$1@news.povray.org>
Reference objects :)
Date: 16 Apr 2001 17:39:43
Message: <MPG.154576d4f6a7039898ce@news.povray.org>
On Mon, 16 Apr 2001 17:12:14 -0400, Olivier Gagnon wrote...
> Wow! Exactly!!!
Erm, select the parent, press Ctrl-D (or select Edit->Duplicate) and
select the Create References option in the Duplicate dialog box.
The reason I didn't tile it the first time round is that I didn't realise
the image would tile seamlessly.
And the advantage of using reference objects is a *major* saving in
memory when rendering.
Bye for now,
     Jamie.
Date: 16 Apr 2001 23:02:43
Message: <3adbb253@news.povray.org>
Thanks!
news:MPG.154576d4f6a7039898ce@news.povray.org...
> > Wow! Exactly!!!
> Bye for now,
>      Jamie.
