POV-Ray : Newsgroups : povray.macintosh : not saving Server Time
26 Feb 2026 12:12:36 EST (-0500)
  not saving (Message 1 to 4 of 4)
Subject: not saving
Date: 12 Feb 2026 06:40:00
Message: <web.698dbba440c72899a6b582f13a93d4b0@news.povray.org>
Using POVRay 3.7.0.x
When I use "not saving" (Image Type Don't Save Image), rendering is OK but
(obviously) the image is not saved.  When I use another Image Type (e.g. PNG) I
get the message "Cannot create render state output file."
Where is the mistake?
Subject: Re: not saving
Date: 12 Feb 2026 09:50:00
Message: <web.698de834dfcd0ee7663764eb6cde94f1@news.povray.org>
you wrote about having this problem a while ago, one reply to your original post
was by the (Apple stuff) maintainer, did you see/read it ?
<https://news.povray.org/69613afe%40news.povray.org>
regards, jr.
Date: 15 Feb 2026 11:10:00
Message: <web.6991ef95dfcd0ee7a6b582f13a93d4b0@news.povray.org>
> regards, jr.
Yes, I wrote about the problem in January, but at that time I did not realise
that the option "Don't Save Image" would work, while selecting for instance
"PNG" would produce the message "Cannot create render state output file.". Why
is ist so, and what can I do to correct the problem?
Date: 16 Feb 2026 03:50:00
Message: <web.6992d9dddfcd0ee7663764eb6cde94f1@news.povray.org>
hi,
I have far too little info, so only can speculate.  (and I do not use an UI
version of POV-Ray).  here, on a GNU/Linux machine, there are two files which
control where POV-Ray can read from and write to, both named 'povray.conf'.  one
is global, the other will be in your user's directory (here '~/.povray/3.7/').
I'd start with checking/customising those.
regards, jr.
