POV-Ray : Newsgroups : povray.binaries.scene-files : AT Devil Plate Server Time
20 Mar 2026 14:50:32 EDT (-0400)
  AT Devil Plate (Message 1 to 10 of 13)
Subject: AT Devil Plate
Date: 4 Apr 2025 10:50:00
Message: <web.67eff108fc8a612c763e4a273b2af915@news.povray.org>
Again I found an other interesting isosurface in Abderrahman Taha's MathMod
which he called Devil Plate (see his functions at the beginning of the attached
pov-file).
But this time I am stuck.
I am posting the pov-file which renders OK although it takes a 'couple
of minutes'. The result is close to the original but
what I could not find out is how to apply thickness
ThickIsoExterior=(Iso(x,y,z,1)*Iso(x,y,z,-1))
and how to apply this condition
F(x,y,z,t) = if(y<(44/10)&y>-(24/10),ThickIsoExterior((10*x/15),y,z,t),1)
Can someone help?
Regards
Droj
Download 'iso_devil_plate.pov.txt' (3 KB)
Subject: Re: AT Devil Plate
Date: 4 Apr 2025 11:45:00
Message: <web.67effe60d1f5ea8e25b4de9225979125@news.povray.org>
That's just a function - like any other.
You might have discontinuities, which would drive the gradient through the roof.
There are likely several ways to go about this.
Enclosing the inequalities in parentheses evaluates them as a Boolean.
If you multiply them, if either one is false, then the product is zero.
If they are both true, then you get 1 * 1 = 1;
so you could try:
F(x,y,z,t) =
select ( (y<(44/10)) * (y>-(24/10)),
0, 1, ThickIsoExterior((10*x/15),y,z,t)
A zero gets added in to use the "4-parameter version" of select, and then since
false = 0, the 1 is the next parameter, and true = 1, so ThickIsoExterior is the
last parameter.
Hope that makes sense.
- BW
select(A, B, C [,D])
It can be used with three or four parameters Select compares the first argument
with zero, depending on the outcome it will return B, C or D. A,B,C,D can be
floats or funtions.
When used with three parameters, if A < 0 it will return B, else C (A >= 0).
When used with four parameters, if A < 0 it will return B. If A = 0 it will
return C. Else it will return D (A > 0).
Date: 5 Apr 2025 08:25:00
Message: <web.67f1205ad1f5ea8e4e78ec763b2af915@news.povray.org>
> so you could try:
> F(x,y,z,t) =
> last parameter.
> - BW
> floats or funtions.
Thanks, B.E.
Now it's clearer what select() is good for.
I have to chew on that for a while.
Date: 26 Apr 2025 16:25:00
Message: <web.680d4033d1f5ea8e7633bf863b2af915@news.povray.org>
> F(x,y,z,t) =
Hi BE,
I followed your advice with respect to select() and added the appropriate code
using the boolean & instead of multiply.
And it works - well, not the way it should.
I believe there is something wrong in my Povray code which is hard for me to
find out.
I added AT's equations as comment above the Povray code.
Meanwhile I read the threads initiated by klp in Povray's advanced users
<6752dcbc@news.povray.org>
in Dec 2024 about the topic but I could not find the solution there.
The interesting thing about my misinterpretation of AT's equations is:
 (1) setting threshold 1 and accuracy 0.01 (max_gradient 2352446)
 ==> Povray renders something solid (not the object I was expecting)
 ==> Trace Time: 1h 38 min using 16 threads
 (2) setting threshold 0 and accuracy 0.01 (max_gradient 2352446)
 ==> Povray renders something invisible
 ==> Trace Time: about the same as above
 (3) setting threshold 0.01 and accuracy 0.1 (max_gradient 2352446)
 ==> Povray renders an object that looks like being peeled
 ==> Trace Time: 0h 39 min using 16 threads
 And no, Povray doesn't complain about gaps in the object!
I will post an image of (1) and (3) in p.b.i
Thanks for your patience
Droj
Download 'iso_devil_plate_test.pov.txt' (4 KB)
Date: 27 Apr 2025 08:15:00
Message: <web.680e1f13d1f5ea8e1f9dae3025979125@news.povray.org>
I don't know what your ultimate goal is, but when I just evaluated the
isosurface for
function {DevilFn2(x,y,z)
I get the following render (Cam and lights adjusted, white sky_sphere)
- BW
Download 'iso_devil_plate_test.png' (39 KB)
Preview of image 'iso_devil_plate_test.png'
Date: 28 Apr 2025 14:00:00
Message: <web.680fc0ecd1f5ea8e397fdce03b2af915@news.povray.org>
> isosurface for
> - BW
When you render the function #declare Iso = function(x,y,z) {
you get the image attached.
The next 2 functions should add thickness to the shape (you see the rim of the
'plate' is thin like an eggshell).
And this is where the flaw is.
Droj
Download 'iso_devil_plate.png' (77 KB)
Preview of image 'iso_devil_plate.png'
Date: 28 Apr 2025 14:30:00
Message: <web.680fc86bd1f5ea8eb00a87a025979125@news.povray.org>
Try Mike Williams' isosurface thickening trick:
Thickening
If we have a function F(x,y,z) we can turn it into two parallel surfaces by
using abs(F(x,y,z))-C where C is some
small value. The original function should be one that works with zero threshold.
The two resulting surfaces are
what you would get by rendering the original function with threshold +C and -C,
but combined into a single
image. The space between the two surfaces becomes the "inside" of the object. In
this way we can construct
things like glasses and cups that have walls of non-zero thickness.
#declare F = function {y + f_noise3d (x*2, 0, z*2)}
isosurface {
function {abs (F(x, y, z))-0.1}
Date: 29 Apr 2025 12:13:20
Message: <6810faa0@news.povray.org>
Am 28.04.2025 um 20:26 schrieb Bald Eagle:
> Thickening
> isosurface {
Obviously this should work. But I run into a problem with this approach.
The yellow object depictes the devils plate function without any thickening:
#declare c=1/10000;
#declare Th=1/10;
#declare Devil = function(x,y,z) {
x*x*x*x+2*x*x*z*z-36/100*x*x-y*y*y*y+25/100*y*y+z*z*z*z }
#declare Devil2 = function(x,y,z) { Devil(x,sqrt(y*y+z*z)-15/10,z) }
#declare IsoExterior = function (x,y,z) { Devil2(x,y,sqrt(x*x+z*z)-15/10) }
isosurface { function { IsoExterior(x,y,z) }
    contained_by { box { <-45/10,-25/10,-75/10>,<45/10,45/10,75/10> } }
    threshold 0.0
    open
    max_gradient 2500
    pigment { colour Yellow }
The red object shows the approach by Abderrahman Taha (MathMod). He
calculates the numerical derivatives to approximate the normals. Then
the shape is shifted a small amount along and against these normals.
Finally, both functions are multiplied to form the sets of points at
which at least one of the functions returns the value zero - the
threshold that is then used in the isosurface:
// numerical derivatives
#declare DFx = function(x,y,z) {
(IsoExterior(x+c,y,z)-IsoExterior(x,y,z))/c }
#declare DFy = function(x,y,z) {
(IsoExterior(x,y+c,z)-IsoExterior(x,y,z))/c }
#declare DFz = function(x,y,z) {
(IsoExterior(x,y,z+c)-IsoExterior(x,y,z))/c }
// normalisation
#declare R = function (x,y,z) { x/sqrt(x*x+y*y+z*z) }
#declare IsoPlus = function (x,y,z) {
    IsoExterior( x+Th*R(DFx(x,y,z),DFy(x,y,z),DFz(x,y,z)),
                 y+Th*R(DFy(x,y,z),DFz(x,y,z),DFx(x,y,z)),
                 z+Th*R(DFz(x,y,z),DFx(x,y,z),DFy(x,y,z)))
#declare IsoMinus = function (x,y,z) {
    IsoExterior( x-Th*R(DFx(x,y,z),DFy(x,y,z),DFz(x,y,z)),
                 y-Th*R(DFy(x,y,z),DFz(x,y,z),DFx(x,y,z)),
                 z-Th*R(DFz(x,y,z),DFx(x,y,z),DFy(x,y,z)))
#declare ThickIsoExterior = function (x,y,z) {
IsoPlus(x,y,z)*IsoMinus(x,y,z) }
#declare DevilsPlate = function (x,y,z) {
    select (  -(-24/10-y)*(y-44/10),ThickIsoExterior((10*x/15),y,z), 1)
isosurface {
    function {
       DevilsPlate(x,y,z)
    threshold 0.0
    open
    max_gradient 20000000
    pigment { colour Red }
The orange object ist nearly the same as the red one but without the
select statement, moving the range condition for y into the bounding box.
This all works very fine, but Mike Williams' approach (dark purple)
looks a little strange:
#declare DevilsPlateD = function (x,y,z) {
      select (
-(-24/10-y)*(y-44/10),(abs(IsoExterior((10*x/15),y,z))-0.01) ,1)
isosurface {
    function {
       DevilsPlateD(x,y,z)
    threshold 0.0
//   open
    max_gradient 1000000
    pigment { colour DarkPurple }
All values for max_gradient are adjusted according to the log.
max_trace_level was at maximum (256).
I have no idea what happens here.
Best regards
Michael
Download 'devilsplate02.png' (173 KB)
Preview of image 'devilsplate02.png'
Date: 29 Apr 2025 14:00:00
Message: <web.681112d1d1f5ea8e4573577725979125@news.povray.org>
MichaelJF <fri### [at] t-onlinede> wrote:
Well, the red and orange are looking good!
I'm not sure what's happening with MW's method, but I was just making a quick
suggestion.
The surface obviously extends infinitely in the +/-y directions, and so the
select is just there to trim the function.
I believe we can exclude that and just rely on the contained_by box.
IsoExterior (10*x/15),y,z) just scales the function in the x direction.
I'd take that out and use scale to take care of that part.
I'm just guessing here, but what if you then try something like:
IsoExterior (abs (x) - 0.01, abs (y) - 0.01, abs (z) - 0.01)
maybe also experiment with subtracting from f_r (x, y, z)
(include functions.inc)
try changing the threshold from 0 to 0.01
There's a lot of tricky things that have to be done to get certain functions to
work well with isosurfaces in POV-Ray vs other software packages
Maybe take a look further upstream at the preceding functions in the daisy chain
to see if a better gradient can be fashioned.
Define a set of y axes across the xz plane in the AABB, and graph the function
along those y-axes and see what pops out.
- BW
>       select (
> isosurface {
>     function {
>        DevilsPlateD(x,y,z)
>     threshold 0.0
> //   open
> Best regards
> Michael
Date: 13 May 2025 09:40:00
Message: <web.68234a53d1f5ea8e9f5def123b2af915@news.povray.org>
> suggestion.
> - BW
I tried some of the solutions proposed here and yes, the orange object is the
best approximation.
When you mentioned to use the function f_r (x, y, z) - although I do not have a
clue what it does (there is no comment in functions.inc) I remembered that TOK
used it in his source code for prettyball_1_at_klp_tok.pov.txt.
I tested it with Abderrahman Taha's Clebsch_2 and it worked amazingly well.
So, I adapted the code for Devil Plate, too which now looks as follows.
// Iso_Devil_Plate_test8.pov
#version 3.7;
global_settings { assumed_gamma 2.2 }
#include "textures.inc"
#include "metals.inc"
#include "functions.inc"
#declare H = 1e-4;
#declare Th = 1/10;
#declare Xmin = -45/10;
#declare Xmax = 45/10;
#declare Ymin = -24/10;
#declare Ymax = 44/10;
#declare Zmin = -75/10;
#declare Zmax = 75/10;
// Devil=x^4+2*x^2*z^2-(36/100)*x^2-y^4+(25/100)*y^2+z^4
#declare DevilFn = function {
 pow(x,4)+2*pow(x,2)*pow(z,2)-(36/100)*pow(x,2)-pow(y,4)+(25/100)*pow(y,2)+pow(z,4)
// Devil2=Devil(x,sqrt(y*y+z*z)-(15/10),z,t)
#declare DevilFn2 = function(x,y,z) {
 DevilFn (
  x,
  z
// IsoExterior=Devil2(x,y,sqrt(x*x+z*z)-(15/10),t)
#declare IsoExt = function(x,y,z) {
 DevilFn2 (
  x,
  y,
// DFx=((IsoExterior(x+c,y,z,t)-IsoExterior(x,y,z,t))/c)
#declare DFX = function { (IsoExt(x+H,y,z)-IsoExt(x,y,z))/H }
// DFy=((IsoExterior(x,y+c,z,t)-IsoExterior(x,y,z,t))/c)
#declare DFY = function { (IsoExt(x,y+H,z)-IsoExt(x,y,z))/H }
// DFz=((IsoExterior(x,y,z+c,t)-IsoExterior(x,y,z,t))/c)
#declare DFZ = function { (IsoExt(x,y,z+H)-IsoExt(x,y,z))/H }
// Adaptation according to TOK's code follows
#declare Fn =
    function(x, y, z, dx, dy, dz, s) {
        IsoExt(
            x + dx*s,
            y + dy*s,
            z + dz*s
// F(x,y,z,t) = if(y<(44/10)&y>-(24/10),ThickIsoExterior((10*x/15),y,z,t),1);
select() removed
#declare DP_Fn = function(x,y,z,dx,dy,dz) {
        Fn(x, y, z, dx, dy, dz, +Th/f_r(dx, dy, dz))
        Fn(x, y, z, dx, dy, dz, -Th/f_r(dx, dy, dz))
        // instead of: IsoPlus(x,y,z)*IsoMinus(x,y,z),
//ISO Devil_Plate =
isosurface {
  function {DP_Fn(
             10*x/15,y,z, // scaling x
             DFX(x, y, z),
             DFY(x, y, z),
             DFZ(x, y, z)
        contained_by{box{<Xmin,Ymin,Zmin>, <Xmax, Ymax, Zmax>}}
        threshold 0.0 // Trace Time 0 h 26 min
        accuracy 0.01
        max_gradient 2216254
        open
        pigment {Yellow}
 rotate 90*y
#declare Win = image_width/image_height;
background { color <1.0,1.0,1.0> }
    location <0, 15, -25>
    up y
    right Win*x
    look_at <0.0, 0.0, 0.0>
    angle 54
light_source {
    <-17, 25, -35>
    color rgb <1, 1, 1>
It's probably as close to the original as it can get.
Thanks to all of you for the input.
Droj
Download 'iso_devil_plate_test8.png' (77 KB)
Preview of image 'iso_devil_plate_test8.png'
