POV-Ray : Newsgroups : povray.binaries.programming : Updated yuqk tarballs for Unix/Linux. b0c8c689 Server Time
9 May 2025 06:14:58 EDT (-0400)
  Updated yuqk tarballs for Unix/Linux. b0c8c689 (Message 1 to 2 of 2)
Subject: Updated yuqk tarballs for Unix/Linux. b0c8c689
Date: 30 Oct 2023 13:26:23
Message: <653fe73f@news.povray.org>
Please see the attached tarballs and previous announcements in this fora
and INSTALL.txt for suggestions on compiling and running via wrapper script.
A reminder the yuqk fork is not POV-Ray. As time passes, it's less
likely existing POV-Ray scenes will work without modification.
Bill P.
----------- povray-3.8.0-x.yuqk_b0c8c689.tar.gz  October 30, 2023
yuqk R10 v0.6.4.0
Renamed this fork of POV-Ray on finding the old name now collides with
an apparently popular adult web site. Functionally, the change is mostly
transparent to the end user except for a few things like the shipped
wrapper script name was changed to 'yuqk'.
In my head, the yuqk fork name is an acronym for, "Yet Unknown Quality
Kaleidoscope" with a varying comma placement (not shown). I'm
pronouncing it like the English word, yuck.
The julia_fractal shape removed which includes the removal of following
keywords specifically dedicated to it: 'cube', 'hypercomplex',
'julia_fractal', 'max_iteration', 'precision', 'pwr', 'quaternion',
'reciprocal' and 'slice'.
The julia_fractal related, secondary, specialized uses of the following
keywords have also been removed: 'acos', 'acosh', 'asin', 'asinh',
'atan', 'atanh', 'cos', 'cosh', 'exp', 'ln', 'sin', 'sinh', 'sqr', 'tan'
and 'tanh'.
Added parse check for duplicate macro parameter names. The macro
definition '#macro ABC(_a,_b,_a) ... #end' will now be considered in
error due the second use of the '_a' parameter name.
The 'component' keyword support in the blob{} was removed. It's been
obsolete for ages.
The 'deprecated' keyword support for identifiers removed. Always
relatively expensive code for something almost never used. Further,
there were bugs (not sorted) around local versus declare directive use
and the existing deprecated support.
Fixed a number of parsing issues related to the 'global' and 'local'
pseudo dictionaries maintained by the parser.
Added internal bitwise functions to rotate bits left or right in
f_64x_ui1_rol() and f_64x_ui1_ror().
Official releases of POV-Ray have always multiplied the caustic exponent
value a user specifies by 45.0 internally. The yuqk fork removed it, as
the multiplier just makes it harder to understand and control the
internal std::pow function used in shaded regions to create the faked
effect.
Added a blend_mode 5 option which is similar to the new option 4 found
for the first time in the previous release - except it peaks in the
middle of the interval instead of at both ends.
Download 'povray-3.8.0-x.yuqk_b0c8c689.tar.gz' (1661 KB) Download 'yuqk_docandaid_b0c8c689.tar.gz' (402 KB) Download 'yuqk_examples_b0c8c689.tar.gz' (103 KB)
Subject: Re: Updated yuqk tarballs for Unix/Linux. b0c8c689
Date: 1 Nov 2023 06:50:00
Message: <web.65422c536d0cd10662ceee076cde94f1@news.povray.org>
hi,
sorry to read about the hassle you were having.
thanks.  hope to put together an email in the coming days re that.
regards, jr.
